Zonk Machine mk1 reducing artifacts and noise?
Started by Reg18, April 26, 2021, 04:16:40 AM
Reg18
I've built a couple of these with OC81 transistors (around 70-100 hfe) and I've had a bit of trouble tuning them. Always get a lot of noise and artifacts in the sustaining notes.
I managed to reduce this by adding a 5nf pull down cap on the input and flipping Q2 around (swapping the emitter and collector pins) this in turn reduced the gain a bit so I altered the 470k to 240k and the 2.2k going to the gain pot to 10k which raised the gain up again. I didn't know this would work it was just trial and error.
Any other ways to reduce the noise and artifacts in a Zonk?
iainpunk
large capacitor between the FUZZ pot and ground might help? it looks odd that the fuzz control changes the bias as well...
cheers
cheers
bmsiddall
Howdy.  What collector voltages do you see?
Cheers,
Brett
Keppy
It looks like that circuit is a slightly modified Tonebender Mk1. Search for threads on that and you should find a lot of info.
Reg18
Quote from: Keppy on April 27, 2021, 11:22:46 PM
Yeah the Zonk Machine by all accounts is a mk1 variant, they can put 1965 so just after the tone Bender which makes it highly like they cloned it. They do sound a bit different though and can be finicky to bias right.
Reg18
Still having trouble building this circuit, tried again today and get the same noises. I've now got a good selection of OC81, Russian GT402 and npn GT404 transistors to swap around.
I have managed to build a few mk1 Tone Benders recently but still can't get a good working Zonk.
After doing some more research I have discovered leaky transistors could be important to getting this build right, I see it is possible to add a resistor (say 500k-1m) across C-B to simulate leakage, will this work in this circuit?
antonis
IMHO, it will not..!! :icon_wink:
By simulating B-C leakage this way, you intervene in bias configuration dramatically..
e.g. Q1 Base will sit at -4.5V and also alter Q1 stage gain due to NFB loop 1M resistor set..
But, as usually, you have nothing to loose by trying it.. :icon_wink:
