Boss SD-1 mods for less bass
Started by Silvio55, May 03, 2021, 01:37:54 PM
Silvio55
Hi! After some troubles I got my SD-1 true bypass clone working fine.
The idea is using it for solo boost only, so less bass would make the mids and higher mids more apparent, sort of like a treble booster.
Many people seems to mod it for more bass, and the starting point for mods seems to change C3, I would decrease instead of increasing its value.
Are there other points in the circuit I should check before? What's your advice on it?
The stock 4K7/47n gives a roll-off at 720Hz, the classic tubescreamer value. You could halve the cap value to 22n and go up an octave and see how it sounds.
R7/C4 are providing some lowpass to smooth the distortion after the clipping amp. That's set at only 880Hz, so if you want a brighter tone, you could reduce that cap a bit too.
R9/C6 are higher up (nearly an octave) but also smoothing the sound out a bit, so again, that's one to look at.
I suspect that you'd get more mileage out of tweaking C4 and C6 to increase the high mids, rather than tweaking C3 to remove more bass. But that's only a guess. If you make C3 too small, you're just cutting all the fundamental out of your notes.
It's a very mids-focussed design, I'd say. The clipping amp rolls off the bass and mainly clips midrange and upwards. Then the subsequent stages roll off plenty of treble to smooth things out and stop it getting harsh. What's left is mids, pretty much.
HTH
Silvio55
Quote from: ElectricDruid on May 03, 2021, 02:09:46 PM
HTH
Thanks! I will try changing C4 and C6 then. I wanted it to sound more like a Rangemaster (not exactly but closer) so I thought that cutting more bass before clipping would work.
There is a difference between modifying how much bass hits the clipping circuitry, and how much bass is coming out of the pedal after clipping has occurred.
Which my first instinct was also to shoot for C3, on reflection I thought it might be better to do the bass reduction further along instead.  The rolloffs around the clipping stage are intended, as in a Tube Screamer, to provide for roughly equivalent clipping across the entire fingerboard, rather than more intense clipping for the low notes and less for the higher ones.  So I recommend leaving the frequency profile around the clipping stage as if.
Instead, consider reducing the value of C7 to maybe 100nf, which will reduce the bass leaving the pedal after all the other stuff has been done to the signal.
Silvio55
Thanks!! I have zero experience in overdrive circuits other than just build clones.
antonis
Quote from: Silvio55 on May 03, 2021, 03:57:22 PM
Just locate all High Pass filters, calculate their respective corner frequency and make R/C mods to make them higher, according to your taste..
(it's just as simple as is said..)
You won't be able to say that much longer!  ;)
Silvio55
Quote from: Mark Hammer on May 03, 2021, 05:48:02 PM
Yeah, I hope so!! Thanks to all of you! I will be experimenting with this circuit and see what comes out!
