Author Topic: Reliable source for CH341A USB controller chip?  (Read 2626 times)
KarenColumbo
« on: May 04, 2021, 12:46:42 PM »
I want to build me one of pedalpcb's "DevBoards" (https://www.pedalpcb.com/product/fv1dev/) for the FV-1. I have Spinsemi's dev board, but it's a bit of a drag to always swap out the EEPROM from the actual stompbox to load it on the dev board then plug it back in again. A lot of work if I just change a line of code and wanna check out if it works ... with the DEVBoard stompbox I just re-up the code directly to the pedal and can test it immediately.
So I ordered a couple of the PCBs, I have a handful of FV-1s, but sadly the USB chip itself, a CH341A seems to be in very short supply, there's only a shit ton of already soldered ones in varying packages. And I anhor desoldering such a tiny thing.
Now I went against my principles and ordered a couple @ Alibaba, but this is not my idea of a serious source. It may well be and I may well do someone injustice, but there you go ...
RS Components, Mouser, Big C, all the usual suspects don't have this one listed.
I also can't seem to Google up direct replacements.
Any idea how to get some of those CH341As?
« Last Edit: May 04, 2021, 12:48:40 PM by KarenColumbo »
“I want something that'll give me the stamina of a young werewolf, the vision of a shaman, the thoughts of a serial killer and the gentleness of a hungry vampire bat.” - Spider Jerusalem
Re: Reliable source for CH341A USB controller chip?
« Reply #1 on: May 04, 2021, 01:03:39 PM »
Following because I'm also interested. I built one of their dev boards a while back when they have the CH341A in stock so they included one, but I'd love to get some more for other experiments.
"I'm not sure what "serious design flaws" you see. Does it explode or poison your dog?" - PRR
« Reply #2 on: May 04, 2021, 02:14:07 PM »
Quick update, I looked around a bit more and it looks like CH341A is exclusively a Chinese chip, which explains why typical reputable suppliers don't carry them. I found some on Aliexpress and ordered 10 for $12.70 total shipped. ETA is about 3 weeks, but we'll see what happens.
KarenColumbo
« Reply #3 on: May 04, 2021, 03:05:07 PM »
Exactly what I did :) Let's see :)
KarenColumbo
« Reply #4 on: May 17, 2021, 11:09:08 AM »
Any news? :) My chips are stuck at customs :)
« Reply #5 on: May 17, 2021, 11:22:28 AM »
Mine were marked as shipped a while ago, but it was shipped with "aliexpress standard shipping" which provides pretty much no tracking info. Apparently I won't know anything until it hits US customs, which it hasn't yet. Estimated delivery is June 15.
KarenColumbo
« Reply #6 on: May 18, 2021, 08:31:53 AM »
I recently bought a few of those on Amazon - they have the CH341A conveniently soldered on top. If all else fails I'll buy some of that low temperature solder and remove it carefully.
« Reply #7 on: May 18, 2021, 09:21:11 AM »
I thought about doing that, I have one of those as well. Currently for most of my FV-1 designs I use an SMD EEPROM and add programming headers to the board, then I use male-female breadboard jumpers and connect the "CH341A Pro" from amazon to the headers. It works fine, but it would be nice to be able to do a more custom setup.
KarenColumbo
« Reply #8 on: May 21, 2021, 11:11:13 AM »
I just like the idea to be able to tweak the patches "live" without having to open the stompbox up, pull the PROM etc. Just connect a USB cable to it, upload the patch to SpinASM, tweak it, re-up it to the box and all that without ever having to put away the guitar or unplug the box from the amp
KarenColumbo
« Reply #9 on: May 23, 2021, 01:38:48 AM »
Got'em today - conveniently the Pedal PCB board was in the post box, too.
If there's trouble with your delivery, I can always send a few of the chips over there
« Reply #10 on: May 24, 2021, 09:16:45 AM »
Excellent, glad you were able to get yours fairly quickly. I'm sure mine will show eventually, but I appreciate the offer. I don't have any urgent need for it right now, but I'll let you know.
