My phase 90 clone isn't working
Started by snow123, June 03, 2021, 05:04:09 PM
jimilee
Quote from: andy-h-h on June 14, 2021, 12:01:24 AM
Quote from: snow123 on June 13, 2021, 11:09:11 PM
tbh i think ill redo the circuit on a new veroboard, but this time 1 step at a time. and how would i do it one step at a time? like would i do the all of the jumper wires and the offboard wiring and then the stuff for the input buffer or what?
Before you tackle this again, try some simpler circuits to get your soldering skills up, and your understanding of schematics / how things work.
This....This is a fairly complex circuit on Vero for a novice. I didn't see any mention of your JFets, are they matched?
snow123
Quote from: jimilee on June 14, 2021, 09:50:07 PM
i think so yea
snow123
ok, im building a bluesbreaker pedal rn, and ive already built a buffer.
snow123
but how exactly would i do the circuit 1 stage at a time?
andy-h-h
Quote from: snow123 on June 15, 2021, 05:07:17 PM
First look at the schematic, and compare it to the layout that you are using.  Map out the parts in your head, or write them down on top of a print out of the layout, maybe highlight sections.
A bluesbreaker is pretty simple.  Things to do;
- check that you have 9v to pin 8, and 0v on pin 4 of the opamp
- make sure you have vref, which is half the supply voltage.  (look for the point where 2 x 47k resistors join, on the schem / layout)
- build the first section, make sure you have level coming in on pin 3, and level out on pin 1.  You should also have level from the 220n cap.
- build the second section, check that you have level coming in on pin 6 and out off pin 7 of the opamp
- the rest is just some passive filtering and the volume control
snow123
#105
Quote from: andy-h-h on June 15, 2021, 05:49:15 PM
how do i check if the signal is going through without doing any offboard wiring?
andy-h-h
you need to use an audio probe, which I think you have
snow123
Quote from: andy-h-h on June 16, 2021, 12:42:41 AM
how do i power the circuit if i just have the input buffer done tho
andy-h-h
You have to have the power portion of the circuit on the board, including the voltage divider for vref.
Quote from: andy-h-h on June 16, 2021, 01:17:22 AM
The power supply and Vref is probably the very first bit to get done, because then you can check you've got 9V to the PCB, and can check you've got a sensible 4.5V Vref. If that alters later on, then you know you've made a mistake somewhere (shorts will often drag these voltages down lower than they should be).
snow123
do i also have to connect the circuit to ground and/or the switch? or just the 9v and input?
antonis
Excuse me but what are you talking about..??  :o
Kevin Mitchell
Quote from: antonis on June 16, 2021, 04:03:03 PM
My thoughts exactly.
I thought you knew how to use an audio probe? Didn't we go over this in your other build thread?
This hobby will be the deaf of me
Quote from: snow123 on June 16, 2021, 03:46:29 PM
You need +9V and ground connected for the power, and the input and output both need the signal wire and the ground connected too. All voltages are relative to some other level. That's usually ground, but it doesn't have to be - witness the "Vref" or "virtual ground" we often have in stompbox circuits, where the voltage is referenced to a 4.5V level.
I'd leave the footswitch out until you've got the board running.
snow123
Quote from: Kevin Mitchell on June 16, 2021, 04:14:40 PM
i know how to use an audio probe, im just asking if i have to connect the circuit to ground and/or the switch to test the power and input buffer stage. or if the probe already ground the circuit or something. just making sure im doing everything right.
Kevin Mitchell
Quote from: snow123 on June 16, 2021, 04:44:20 PM
Oh okay.
As long as the switch is just a bypass switch you can do with or without it when it comes to probing a circuit - as long as you've got signal on the circuit's input. You will need the input plugged in or else you wouldn't have a signal to track with the probe. The circuit does need to be powered with your 9v(with ground). I mean, I'm sure it'll work via your amplifier's ground through the probe but that's not how it should be. You must properly power your circuit for it to function as intended. Improper ground could lead to odd behavior and wonky readings. Mostly noise issues.
Plug in the circuit just as you should - minus the output since you're using an audio probe instead of it's main output.
Make sure the probe's ground is connected to your circuit's ground.
snow123
Quote from: Kevin Mitchell on June 16, 2021, 05:04:52 PM
Oh okay.
ok, thanks.
andy-h-h
I'm confused - didn't you say that it's now working in this thread, before these recent posts?
https://www.diystompboxes.com/smfforum/index.php?topic=127366.0
GGBB
In most true bypass pedals, bypass mode will ground the circuit's input. So you can't do without the bypass switch - the pedal must be engaged not bypassed.
snow123
Quote from: andy-h-h on June 16, 2021, 06:24:34 PM
i was building a bluesbreaker pedal, and i had a minor issue with it, and fixed it.
