My phase 90 clone isn't working
Started by snow123, June 03, 2021, 05:04:09 PM
andy-h-h
#20
Quote from: snow123 on June 04, 2021, 05:28:37 PM
Better?
It still needs to be cleaner.  Even a small spot across tracks can be a problem on vero - see marked-up image.  The tracks in between conductive strips should not have anything in them at all.
The areas with big black marks etc are still concerning.  There's a lot to clean-up.
As others have said, scrape it clean with small screwdriver.  Sometimes a reflow with the soldering iron and flux is also needed before you can do this.  It's really difficult (near impossible) to scape off solder that's overflowed across tracks.   If you have isopropyl alcohol (99% alcohol) give it a light spray afterwards and a clean with a toothbrush just to be sure.
snow123
snow123
actually the signal just comes out as more distorted but quieter, not weaker.
andy-h-h
Quote from: snow123 on June 05, 2021, 12:05:50 AM
Still haven't seen any voltages.  It'a guessing game without them.   ;)
stallik
After using the blade/screwdriver between the tracks, I use a stiff, dry toothbrush to polish it up and remove the last bits of crud that I can't see. Any discolouration of the solder at this point should be reflowed.
I'm lucky to have an extremely powerful dissecting scope that really shows how dirty vero can become. One little bit of crud left over is all it takes to break the circuit
snow123
Quote from: andy-h-h on June 05, 2021, 01:32:05 AM
i have the multimeter on 200 DCV with the black probe to ground and the red probe to the legs/pins, and i used a battery snap that plugs into the dc jack for powering the circuit.
transistor voltages: (Q1-Q4 are 2n5457s instead of 2n5952)
Q1
D = 8.1
S = 8.2
G = .9
Q2
D= 8.1
S= 8.2
G= .9
Q3
D = 8.1
S = 8.2
G = .9
Q4
D= 8.1
S= 8.2
G= went from .8 to .9 and stayed at .9
Q5 (2N4126 instead of 2n4125)
C = 4.8
B = 5.2
E = 8.2
ICs (top to down)
IC1 (top)
P1 = 8.3
P2 = 8.3
P3 = switched between 8.0 and 8.1
P4 = 0.0
P5 = 8.0
P6 = 8.3
P7 = 8.3
P8 = switched between 9.0 and 9.1
IC2 (middle)
P1 = switched between 8.2 and 8.3
P2 = 8.3
P3 = 8.0
P4 = 0.0
P5 = 8.0
P6 = 8.3
P7 = switched between 8.2 and 8.3
P8 = 9.0
IC3 (bottom)
P2 = switched between 8.2 and 8.3
P3 = 5.6
P4 = 0.0
P5 = randomly switched between 6.5, 6.6, 6.7, and 6.8
P6 = 6.9
P7 = switched between 6.5, 6.6, 6.7, 6.8, 6.9, 7.0, 7.1, 7.2, 7.3, 7.4, 7.5, 7.6, 7.7, 7.8, 7.9, 8.0, 8.1, 8.2, and 8.3
P8 = 9.0
D1 (5v1 zener)
Anode = 5.4
Cathode = 8.1
andy-h-h
Hello
Those voltages are pretty off - compare to this  http://www.generalguitargadgets.com/pdf/ggg_p90_instruct.pdf
Check your biasing first, and see what's happening there.   Sometimes it's good to pull the IC's etc out and see what's happening without them (voltage where it should not be)
snow123
snow123
ok, when i took out the ics i got this:
Q1 - Q4 voltages:
D = 8.3
S = 8.5
G = 3.9
Q5 voltages:
C = .7
B = .9
E = 8.5
andy-h-h
Quote from: snow123 on June 05, 2021, 11:56:15 PM
Q1 - Q4 voltages:
D = 8.3
S = 8.5
G = 3.9
Q5 voltages:
C = .7
B = .9
E = 8.5
What voltages are you getting in the empty sockets?   I'd check for continuity across the tracks - good chance you still have issues as you have voltage where it doesn't belong.
Is D1 definitely a 5.1 zener?
Quote from: snow123 on June 05, 2021, 11:39:33 PM
how would i check my biasing tho
What's the voltage across the 250K trimmer R22, or equivalently between the legs of C6/10uF?
It should be 5.1V because D2 is a 5.1V zener diode that sets the bias, but on yours it looks like it's over 8V, so something's up.
(Note I'm using part names from http://www.generalguitargadgets.com/pdf/ggg_p90_sc.pdf - I don't know if the the perf layout renamed things or not).
snow123
#31
im pretty sure the vero layout im using is based on this tonepad schematic/pcb: http://www.tonepad.com/project.asp?id=7
snow123
Quote from: andy-h-h on June 06, 2021, 03:13:41 AM
Q1 - Q4 voltages:
D = 8.3
S = 8.5
G = 3.9
Q5 voltages:
C = .7
B = .9
E = 8.5
wait i just realized i accidentaly desoldered d1's anode lmao
snow123
Q1 - Q4 voltages:
D = 8.3
S = 8.5
G = 3.9
Q5 voltages:
C = .7
B = .9
E = 8.5
ok these are the IC socket voltages without the op amps in them
IC1 (top)
P1 = 0.0
P2 = 0.0
P3 = 4.2
P4 = 0.0
P5 = 4.2
P6 = 0.0
P7 = 0.0
P8 = 9.0
IC2 (middle)
P1 = 0.0
P2 = 0.0
P3 = 4.2
P4 = 0.0
P5 = 4.2
P6 = 0.0
P7 = 0.0
P8 = 9.0
IC3 (bottom)
P1 = 0.0
P2 = 0.0
P3 = 2.9
P4 = 0.0
P5 = 3.2/3.3
P6 = 0.0
P7 = 1.4
P8 = 9.0
snow123
Quote from: ElectricDruid on June 06, 2021, 04:50:27 AM
with the black probe on ground, all the transistors and op amps in the sockets, and the trimpot maxed out, heres the trimpot voltages:
fixed end 1: 4.2
fixed end 2: 0.0
variable end: 4.2
snow123
#35
and i am using a battery snap for voltages and stuff so voltages might be a little off
snow123
when i put the DMM on diode test mode and put both probes on D1 i get about 1.71 volts.
snow123
btw i did fix d1's solder joint lol right after i mentioned it
andy-h-h
Any photos of the board from above showing all components?
snow123
