LPB 1 no sound in bypass or through circuit
Started by StompBoxNovice, June 10, 2021, 01:02:59 PM
StompBoxNovice
So, my first full pedal project, did some op-amps years ago as well as some breadboard pedals using programmable chips.
I decided on an LPB-1 as it seemed easy and would fit in my enclosure (old tobacco tin) for some reason, even the bypass doesn't let signal through. There is a hum in bypass, but no audio.
Any help would be much appreciated, using a multimeter, there is a signal path in bypass but not through the PCB.
Marcos - Munky
First of all, welcome!
We need more photos of your build, showing the board both sides and jacks wiring. Also are you sure nothing is touching the metal enclosure and causing a short?
StompBoxNovice
#2
My thanks!
Been lurking for a bit whilst I was waiting for parts, was hoping for a "Look at my first build, isn't it great" post, but unfortunately not!
The casing has been lacquered, so is no longer conductive.
Both Jack's have been wired the same, with the black cable being earth.
Many thanks!
Sorry, hard to get good photos with the cabling in the way, but it's the same as the design further up
Quote from: StompBoxNovice on June 10, 2021, 06:21:50 PM
Good for board isolation but bad for external interference.. :icon_wink:
Could you plz post a 3PDT switch wiring schematic..??
BTW, Volume pot is wired backwards..
(lug 1 should go to GND..)
P.S.
Welcome, also.. :icon_biggrin:
StompBoxNovice
Quote from: antonis on June 10, 2021, 06:52:32 PM
P.S.
Many thanks for the welcome and the heads up about the volume pot, I'll switch it around in a second.
In regards to the 3PDT, left to right is output, input LED with position 1 being bypass and position 2 being PCB
also welcome, and no green face from me.
it is my opinion only, but I think your statement about wired the same is incorrect. the above photo suggests to me that you have wired that jack to the normally closed contacts [that is, when you shove in a plug, the contact opens] instead of the common contacts [that is, the contacts that swing in the switch, common to both open and closed states].
because one jack faces up and the other faces down, but the wires are on top on both.
StompBoxNovice
The jack's have a constant connection, they only move to entertain space for the male Jack. Either side can be soldered and it will connect (I'm guessing these inputs were designed for breadboards more than anything else, giving you the ability to attach on either side of the break)
well, now you've got me, I don't understand. can you take a photo of the jack with a plug inserted, showing the fingers, please? I might need to do a red face instead.
FiveseveN
Quote from: StompBoxNovice on June 11, 2021, 11:27:31 AM
Nope. Plug a jack in and check again, duck_arse is correct.
StompBoxNovice
DuckArse was correct, my apologies!
The bypass is working! The PCB was working until I tried putting it into the enclosure, I'll have to go over it again tomorrow, see what's happening! Thanks for the help!
GibsonGM
Quote from: StompBoxNovice on June 11, 2021, 02:24:39 PM
With a metal enclosure like that, you must put thick cardboard, non-conductive foam, tape, or something else inside to make sure the bottom of the PCB will not touch the metal. If it does, it can short out, making the effect go silent or WORSE, it could cause components  to short and fry!!   Make SURE nothing can touch the metal bottom, walls, or top of the can...I hope it works when you take it out, then you can insulate the box...
I use a packing foam, cut to fit, that is definitely non-conductive (some of it can be), it is similar to pipe insulating wrap or the foam they use on bikes to you don't fall on the bar badly...  ;)
Quote.... you don't fall on the bar badly...
this happened to me once.
the easy way around the switching aspect of those plastic jacks, I find, is to simply link across each set of pins. I doubt there are many here who haven't been caught using the wrong pins on a plastic jack at least once.
WoundUp
I actually just got done breadboarding this exact circuit and was having my own problems. It was dead silent. First, I had to redo the circuit because I mucked it up somehow. Then I tried again and same thing. It took me about 15 minutes of head scratching to realize I forgot to put power to part of the circuit that runs to the collector of the transistor lol.
I had already given up for the night and everything. Then it hit me that I forgot to power the dang thing  :icon_lol: It works great now. I'll probably try it on perfboard next. I don't have an enclosure to use for it so I'll have to wait and build it out once I get one.
