A little help with disaster transport jr please
Started by whomeno, July 28, 2021, 03:49:51 PM
whomeno
Just built this one and have no delay what so ever. I just get a solid tone, no delay to it. I have checked for all the normal things and can not find what is wrong.
hopefully someone can see what I'm over looking. Thanks
Voltages 9 Volt in
78L05
I- 8.93
G- 0
O- 4.99
TL072
1- 4.46
2- 4.44
3- 4.35
4- 0
5- 4.44
6- 4.44
7- 4.44
8- 8.93
PT2399
1- 4.99
2- 2.44
3- 0
4- 0
5- 3.08
6- 2.41
7- 0.53
8- 0.57
9- 2.44
10- 2.44
11- 2.44
12- 2.44
13- 2.44
14- 2.44
15- 2.44
16- 2.44
Gear as of now
Gibson 2017 Les Paul Tribute T
Epiphone Les paul Special (upgraded)
Marshall DSL 20 Head
Peavy Valve king 20 W
2 X 12 Cabinet with celestion vintage 30 & celestion G12T-75
And a lot of pedals
whomeno
ok, did some probing, I got sound heading in to the feed back. I loose it at R13, I have it at the top of the 10K but nothing going through
Gear as of now
And a lot of pedals
antonis
#2
MOve R13 lower leg (the one close to yellow stripe) one row upwards.. :icon_wink:
whomeno
the resistor you are talking about is R12 47K R13 10K is to the right right above the hole.
Gear as of now
And a lot of pedals
antonis
OK.. ignore its number name and procced as I told you.. :icon_wink:
whomeno
Sorry, I made the change with the resistor. still the same.
Gear as of now
And a lot of pedals
whomeno
i made this tester to be sure the PT2399 was ok.it worked fine
Gear as of now
And a lot of pedals
whomeno
I got a family emergency. might be a few days till I can get back to this
thanks for the help so far.
Gear as of now
And a lot of pedals
whomeno
  ok back. took care of all the mistakes you seen and still no delay.
Gear as of now
And a lot of pedals
any change to voltages? can we see new pics?
whomeno
TL072
1- 4.43
2- 4.47
3- 4.33
4- 0
5- 4.42
6- 4.43
7- 4.4
8- 8.90
2399
1- 4.99
2- 2.44
3- 0
4- 0
5- 4.49
6- 2.5
7- 0
8- 0.2
9- 2.44
10- 2.44
11- 2.44
12- 2.44
13- 2.44
14- 2.44
15- 0.72
16- 2.44
Gear as of now
And a lot of pedals
anotherjim
I don't like PT2399 pin5 voltage. It should be closer to 2.5v. I suspect static charge lockup. Try discharging all the PT2399 pins into something conductive for 10 seconds or so - With no power on obviously!
whomeno
Gear as of now
And a lot of pedals
with all respect due to antonis, put it back.
there are a few points of interest on the solder side.
the arrow points to what looks like a hairline fracture in the trace. you also need to show a lighteer touch with the scoring knife, there's some ugly looking damage in places. slivers of copper will bridge tracks just as nicely as solder blobs. and - the solder sucker - it produces great loads of dry solder crumbs, which drop from the chamber when the suck is done. there's loads of junk all on the board looks like sucker crumbs, it all needs to be cleaned away. and whatever that ugly spotty stuff on topside is, it also needs brushing away.
any lead positionings we can't see in your photos are for you to make sure of.
whomeno
thanks for your honesty!. I have corrected all points. here are updated pics. still no delay
Gear as of now
And a lot of pedals
whomeno
I just don't get it on this one.
I built the madbean Leviatan with a 2399 and worked fine first time.
Thanks for all the help so far guys
Gear as of now
And a lot of pedals
pin 15 voltage is way wrong. follow along the tracks from pin 15 and 16 and check those solders, there is a couple that still show unfilled joints. power off, pull the IC out, and measure the resistance between pins 15 and 16, and the R10//R11 junction and 15, 16.
oh oh oh and - we have not seen a shot of your offboard wiring, pots and jacks, which is often the/a problem.
whomeno
#18
resistance between pins 15 and 16-57K
pin 15 2.43  as of now
R10 R11 -0
R10 -pin 16-20K
R10-pin 15-57.1K
top of R11-pin 16-9.9K
top of R11-pin15-47K
off board wiring
Gear as of now
And a lot of pedals
well those resistance measures look right. what is the markings on that little blue cap?
I can't see anything amiss, you'd better try the audio probe again, see if any changes there.
