A little help with disaster transport jr please
Started by whomeno, July 28, 2021, 03:49:51 PM
whomeno
the blue cap was a 2.2nf changed it to a 22nf.
probed have tone at R11 & R13 connection, but nothing at R13 and pin 16
I built another board, it dose the same thing
Gear as of now
Gibson 2017 Les Paul Tribute T
Epiphone Les paul Special (upgraded)
Marshall DSL 20 Head
Peavy Valve king 20 W
2 X 12 Cabinet with celestion vintage 30 & celestion G12T-75
And a lot of pedals
anotherjim
pin16 is an opamp "virtual ground". You shouldn't expect to hear anything on it. Pin15 is the audio going into the delay, you should hear something on that.
whomeno
ok.  probed again
at connection R13 10K and R12 47K got good tone
AT R12 47K and pin 15 no tone.
Gear as of now
And a lot of pedals
whomeno
I don't know whats going on with this board, but I just built another board from a different layout, used the same ic's and it worked the first time.
Thanks for ALL the HELP.
Gear as of now
And a lot of pedals
Quote from: whomeno on August 01, 2021, 11:56:20 AM
I have some questions. this new layout [link to, please?], what value cap did it call for at "C22", 2n2? and what value did you fit? I'm not real good with opamp filters, but a general rule of filters is that you can't replace a cap with one 10 times bigger and expect the same performance - and those MFB filters are picky about values. one of the gurus might elucidate for us.
if I might be so bold as to suggest going back to the faulty board and removing the 22nF and replacing with say a pair of 1nF in parallel, just tacked on to test, and see what happens. you might end up with two working boards for the price of one.
whomeno
Here is the last one i used. it seems all values are the same, just the board is a little bigger.
Gear as of now
And a lot of pedals
