Help me with Idiot Wah
Started by moreforest, July 29, 2021, 11:19:20 AM
moreforest
Hi everyone. I tried to create an Idiot Wah for the first time, but the sound is a little overdriven when I am actively playing the guitar. I tried to regulate the resistors in feedback, but I didn't get a good result. I have not seen on the forums that someone had the same problem. Mpsa13 transistors,
Help who knows
soggybag
Have you tried adding a pot in series with the 22uf cap on the emitter? This would create a gain control.
moreforest
Quote from: soggybag on July 29, 2021, 11:55:20 AM
Sure. Values above 22u do nothing, and decreasing capacitance leads to more dirt.  :icon_frown:
I think that the point is in the bias of the transistor. It would be very cool if someone could give the voltage values on the EBC of the transistor  ::)
soggybag
 I meant replace the 10k resistor with a 10k pot. Move the 22uf cap between the wiper and ground. Pins 1 and 3 of the pot should go from emitter and ground.
moreforest
Quote from: soggybag on July 29, 2021, 02:09:59 PM
in one position of the potentiometer 10K - the "wow" effect is there but with overload. in other positions of the potentiometer, the "wow" effect disappears and the LDR does not react to light. (((
I think to find others LDR
antonis
Quote from: moreforest on July 29, 2021, 04:20:34 PM
Hi & Welcome..
Could you plz point out that LDR..??
moreforest
Quote from: antonis on July 29, 2021, 04:49:45 PM
Hi & Welcome..
Light resistance at 10 lux: 8-20 kΩ
Dark Resistance at 0 Lux: 1.0 MΩ
^ is the LDR in place of the pot??? (remove pot) then add the LDR.
e.g one leg connected to between the caps in the 'T' filter
and the other leg to ground?
while im here, the morley wah is a good clean wah for LDR use, it was designed for that.  :)
Quote from: moreforest on July 30, 2021, 07:51:14 AM
Hi & Welcome..
touché!
antonis
