Author Topic: 78l05  (Read 964 times)
brujo
78l05
« on: September 18, 2021, 01:44:28 PM »
Hi there, I build this crap-fi delay (pt2399) but I'm getting only 1,5v on 78l05 output,any suggestions?
antonis
Re: 78l05
« Reply #1 on: September 18, 2021, 02:36:03 PM »
Flip 78l05 180o..
brujo
Re: 78l05
« Reply #2 on: September 18, 2021, 02:42:02 PM »
I will try It,thank you
Cheeers
The delay Is After a ne555 oscillator,and they share 9v . Let's are
Yazoo
Re: 78l05
« Reply #3 on: September 18, 2021, 06:08:59 PM »
Sorry to be a contrarian, but the orientation for the 78l05 shown on the layout is correct. If it was a full 7805, not the TO92 version used here, you would have to rotate it.
Re: 78l05
« Reply #4 on: September 18, 2021, 07:32:49 PM »
You could measure the current going into the board.  (To measure current you need to wire the meter in series with the power.  Once you make the measurement set the meter and probe positions back to volts straight away.)
« Last Edit: September 18, 2021, 07:36:32 PM by Rob Strand »
Re: 78l05
« Reply #5 on: September 18, 2021, 07:41:23 PM »
No-one said the layout was wrong, only that if you're getting 1.2V out of it, putting it in the other way around is a likely solution since it's probably back-to-front.
I've made this stupid mistake enough times to know by now, but it still happens.;)
If the PT2399 is socketed, you could test it with the chip taken out. It's good practice to check power voltages first before putting chips in, in general. Another potential cause is something dragging the output down, like a bad 2399, or a short.
HTH
antonis
Re: 78l05
« Reply #6 on: September 19, 2021, 06:27:57 AM »
Another potential cause is something dragging the output down, like a short..
Actually a "short" in the form of 32/10 voltage divider.. :icon_wink:
brujo
Re: 78l05
« Reply #7 on: September 19, 2021, 08:58:58 AM »
Here
Re: 78l05
« Reply #8 on: September 19, 2021, 10:52:53 AM »
what voltage do you have on pin 2 of PT?
Re: 78l05
« Reply #9 on: September 19, 2021, 06:26:25 PM »
It's a marker pen dot over a PCB hole identifying a PCB cuts.   Looks a bit odd in the pic I think it's light blue.
So no pin 2 Ref cap.
« Last Edit: September 19, 2021, 06:28:25 PM by Rob Strand »
brujo
Re: 78l05
« Reply #10 on: September 22, 2021, 11:38:37 AM »
it was a bad 78l05,probably connected with reversed polarity?!
this is voltages on pt2399
1=5v
2=2.5v
3=0v
4=0v
5=3.45v
6=2.5v
7=0.65v
8=0.65
9=2.5v
10=2.5v
11=2.5v
12=2.5v
13=1.3v
14=2.8v
15=2.5v
16=2.5v
