Talk box question(s)
Started by fowl, September 20, 2021, 12:04:04 AM
stallik
Pink, what's your experience with the sound from these drivers? Is it normal for them to distort very easily? That's an issue I have even with tiny amps
Distortion in a talkbox signal chain is a good thing.  You're using your mouth as a resonant cavity to achieve subtractive synthesis - carving away unwanted harmonic content.  To do so effectively, and audibly, you need to start out with more harmonic content, in order to have something to remove.  Not "ugly" distortion, mind you.
srvpoet
Quote from: Jdansti on September 20, 2021, 04:44:31 PM
Quote from: PRR on September 20, 2021, 01:55:30 PM
> JBL D250-X driver.... ~40W tube amp
After listening to my Dad's Frampton Live album when I was a kid, I tried hooking up a mono earphone to my guitar amp and putting the earphone in my mouth. Boy was that a hot mistake!
I did the same in about 1991. The earphone smoked quickly!  LOL
Jdansti
Quote from: srvpoet on September 27, 2021, 05:38:22 PM
:D Glad to know I'm not the only one!
pinkjimiphoton
Quote from: stallik on September 27, 2021, 02:16:11 PM
yeah they should distort fairly easily usually. the old ones i use usually have metal diaphragms that can really take some abuse. the distortion helps make consonant sounds. a "clean" talkbox is fairly meek, but a dirty one can really get squawkin'
Slava Ukraini!
~Jack Darr
fowl
Quote from: pinkjimiphoton on September 27, 2021, 09:31:07 PM
"maybe you should stay with yo mama....."
You should never smoke in pajamas...
pinkjimiphoton
please don't start a fire, and burn your face....
Slava Ukraini!
~Jack Darr
MrStab
"Tiny Class D amplifier in the enclosure!"
who said that?! show yourself!
Recovered guitar player.
Electronics manufacturer.
pinkjimiphoton
long as it got enough nards, those will work. i have used them to do it. hard to supply enough power to it to really get much power out of 'em, but essentially that's the 44 magnum i use to drive mine with now.
Slava Ukraini!
~Jack Darr
fowl
I found a Hammond box size for this project.  1590V.
Big enough for this honkin' JBL driver?  Yep.
Big enough for the driver and a mono speaker jack?  Yep.
Big enough for the driver, jack, and a (cap/no cap) toggle switch?  Yeah, probably.
Big enough for the driver, jack, toggle, and this massive crossover cap?  Uh...maybe.  Hard to tell without one in hand.
pinkjimiphoton
remember, the cap isn't all that important, and doesn't need to be particularly high voltage or large if you choose to use one.
cool box, i may get one for mine in fact! thanks bro
Slava Ukraini!
~Jack Darr
fowl
The driver fit in the Hammond 1590V with a couple mm to spare all around, lol.  Plenty of spare height for the cap and everything.  I have some stiff styrofoam bits supporting the driver from underneath, might cut a dowel.  The hose adapter thing is a 3-D printed piece from Ebay.
pinkjimiphoton
Slava Ukraini!
~Jack Darr
fowl
Thanks.  I'll probably relabel "Cap<>Bypass" to "HPF<>Bypass" just because.  It's a very audible difference FWIW, I think most would prefer the sound without the cap.
pinkjimiphoton
like i said, you don't need a cap. the cap limits the lows. only necessary with midrange drivers or tweeters. that's why the old-school full range pa horns are best.
Slava Ukraini!
~Jack Darr
