Author Topic: EHX Small Clone mods?  (Read 3520 times)
zachlovescoffee
Re: EHX Small Clone mods?
« Reply #40 on: October 24, 2021, 03:31:59 PM »
The attached picture looks to be posed to mislead and confuse... it almost looks like the wires "went" where you are holding them, but that's just a "guess" on your part.
Itís definitely wasnít my intention to mislead. It was an uneducated guess.
Can you see those two pads are labeled? Can you read what the labels say? Can you guess what those labels mean?
Hint: you're probably right in thinking that one leg of the switchwent to the ground somewhere like the input jack.
Orange wire says S1_2 and the white says J3_9V.
So the wire white must go to the DC jack and be ignored for the rest of this conversation because itís not germane relative to the 2k7?
That means that the 1 lug from the pot must go to one side of the 2k7 and the other side must go to the mono jack lug and then to ground? The question then is left side or right side?  :icon_eek:
idy
« Reply #41 on: October 24, 2021, 07:09:16 PM »
Good on you for figuring out the legends. Yes, the one marked J goes to the 9v power jack.
Lets just leave the 2.7k out. It goes nowhere now.
The pot that takes their place has pin 3 going to the hole for the 4.7k that goes to the Lm358, pin 1 goes to ground, and pin 2 (the wiper) going to the 39k and 10uf cap to ground (that would be the other hole for the 4.7k. Capiche? This method will however give you no depth at all at minimum.
You are just going to stick a 1k (or lower) in a cut in the wire from pot pin 1 to ground. It is not necessary, the versions of this mod I have seen(and done) don't do  don't add it. Just put a wire there and confirm it works. Then if you are obsessed by the lack of modulation at "0" snip the wire and stick an R in there.
the side of the 4.7k that went to pin one of the 358 goes to pot pin 3 (your "hot" lfo signal).
The other side of the 4.7k goes to pot pin 2. The wiper, the output of your depth pot going on to wiggle the clock (CD4047) speed.
Pot pin 1 goes to ground.
same thing again, yes? The two sides of 4.7k, one to pin 3, one to pin 2, wire to ground? Third times the charm! If you have doubts as to "which side of the 4.7k" I think that has been answered also. You're so close!
How about this: The right side of the 4.7k goes to pot pin3.
The left side of the 4.7k goes to pot pin 2.
Pot pin 1 goes to ground, possible with that wire interrupted by a 1k or so R.
the 2.7k is irrelevant.
zachlovescoffee
« Reply #42 on: October 24, 2021, 07:51:14 PM »
Okay I have the 4k7 done except grounding lug 1 of the pot. Iíll just ground it to an input jack unless you have a better suggestion? See pic!
So now I have an output jack that needs to be grounded. Methinks I can ground both the depth mod pot and the jack to the DC jack?
« Last Edit: October 24, 2021, 08:00:10 PM by zachlovescoffee »
idy
« Reply #43 on: October 24, 2021, 08:01:41 PM »
Yes, jacks need to be grounded.
I can't know what you mean by
used to be connected to the now empty 2k7
The wire must have gone to a pad on the PCB? That pad must still be there? Still grounded? You can test for continuity?
If you have an empty pad where a wire used to be grounded, you can put that wire back there and it will be grounded again, no?
zachlovescoffee
« Reply #44 on: October 25, 2021, 09:57:07 AM »
Alrighty, so this morning I hooked up everything and tested it. The pedal powers on but there is no output. There is nothing connecting the left pad to the right pad of the 2k7 now. There is continuity between the left lug of the erstwhile 4k7 (lug 2 of pot now) and the right hand side of the 2k7. For what that's worth I don't know.
I'm kind of at a loss for why there is no output now. I hooked everything back up. Power to the board is hooked back to the DC jack. The ground for the board is also on the DC jack. The output lug is grounded to the DC jack along with lug 1 of the depth pot. Both output jacks are bolted back on to the pedal.
Any thoughts would be welcome.
idy
« Reply #45 on: October 25, 2021, 01:29:01 PM »
All jacks grounded? Voltages on ICs? Do you have a "signal probe" (guitar cable with a cap soldered to the signal conductor)?
2.7k R is irrelevant. The mod you did will not kill the signal, only possibly affect the modulation. But did you find a place to ground (possibly through a small R) pin 1 of depth pot? Probably there was no pad, and EHX just put the grounds together on the in jack.
Bypass still works?
Have you ever read the problem solving FAQs here or anywhere else?
zachlovescoffee
« Reply #46 on: October 25, 2021, 02:11:56 PM »
I don't have this but I am going to look up how to build it.
I grounded everything back to the DC jack. I did not put a small resistor on the depth pot but I'm open to it.
[/quote]
Bypass still works?
At the time bypass was not working but I figured out the problem and now the pedal is working and it sounds wonderful. Though, I am still getting a pop when engaging the pedal for the first time. I may need to figure out a pull down resistor solutions.
Woot!
« Last Edit: October 25, 2021, 03:36:59 PM by zachlovescoffee »
zachlovescoffee
« Reply #47 on: October 25, 2021, 02:43:05 PM »
For vibrato mod I only have DTDP (on/on) and (on/on/on) and one 3PDT (on/on) toggle switch and 3PDT stomp switches.
I tried a 3PDT stomp switch (w/ 22k wired in) and when itís in the vibrato works perfectly. But when itís off I donít get any chorus signal at all. Itís weird.
Maybe I have to run two pairs of wires from each side of the a toggle (on/on) switch One side will have the 22k on it and the other side wonít have the 22k. Flip it up and the down side has only wires to pass vibrato. Flip it down and it flips to a 22k wired with two lines also going to the same spot as the first pair but now itís passing the signal through the 22k to get chorus? Maybe Iím just making shit up?
« Last Edit: October 25, 2021, 06:42:00 PM by zachlovescoffee »
zachlovescoffee
« Reply #48 on: October 26, 2021, 10:34:58 AM »
I got it! I just had to think about the switch and test it with different configurations and use the continuity tester. Et voila!
Man these two mods alone take the sounds coming from this pedal to new levels. Now I just need to figure out how to add the bi-color LED (blue/red common anode) on so that when itís in chorus mode there is a blue light and when itís in vibrato mode there is a red light.
Govmnt_Lacky
« Reply #49 on: October 26, 2021, 11:10:37 AM »
For that you would need to replace the DPDT toggle with a 3PDT toggle  ;) Run the common anode to V+ (9V?) and the ground, via an LDR, to the unused center lug of the 3PDT. Outside lugs would go to the 2 different cathodes of the LED.
for an amount of Ďup to and including my life.í
zachlovescoffee
« Reply #50 on: October 26, 2021, 11:24:53 AM »
Hello! Thank you! Itís actually a 3TDP toggle (on/on). Will that work?
Govmnt_Lacky
zachlovescoffee
zachlovescoffee
« Reply #53 on: October 26, 2021, 01:26:31 PM »
I wired it up as such with a 4k7 resistor going from the common anode to the unified central lug of the 3TDP switch. The cathodes of each LED are then wired to their respective 3rd lug on the outer rail of the switch. I have continuity at all expected points.
However, when I apply 9v I get nothing from the LED. My power LED works but this one on the toggle is not working. Iíve tested it with a 3.2v battery and itís fine.  Any ideas?
idy
« Reply #54 on: October 26, 2021, 02:44:34 PM »
You don't have a picture of what you have wired up, the thing you are asking about. The photo shows the old resistor between terminals 4 and 7 of your 3pdt and the wires ( going, I assume) to the pads it used to occupy) are attached to terminals 5 and 8.
Do you get these numbers? When we talk about a 3pdt switch we use this ordering
1 4 7
2 5 8
3 6 9
lugs (or terminals) 1, 2, and 3 make a switch pole. Same with 4, 5, and 6 and etc.
so confusing... unified? 3rd lug? outer rail?  so uninformative, so vague.
try this:
1) The common anode, with its 4.7k (Current Limiting Resistor, CLR) goes to 9v+.
2) a ground wire goes to terminal 2 (which you could call the middle lug of the outside (left-most) pole of the switch.)
3) the two cathodes go to terminals 1 and 3.
Note: this method will leave your new LED on all the time (red or blue) even when the pedal is bypassed. To make it so the bypass also turns this bi-color LED off you will need a ground wire that goes to the bypass foot switch. One of its poles switches the ground of the status LED.
1)Find where the status LED cathode (-) is attached to the stomp switch.
2) the lug next to it should be ground.
3) attach your new bicolor LED ground wire to same lug as the status LED cathode.
Govmnt_Lacky
« Reply #55 on: October 26, 2021, 02:44:56 PM »
Wire like this:
Red LED Cathode ------> Pole
Ground ------> Center pole
Blue LED Cathode -----> Pole
9VDC ----> 4K7 resistor ----> Directly to LED Anode
zachlovescoffee
« Reply #56 on: October 26, 2021, 02:59:32 PM »
Wire like this:
Iím uncertain here. There are three legs. A common anode (+) and two cathodes, one for red and one for blue. You say one cathode each to the pole. A new +9vdc to the anode and a new wire from center lug to ground?
idy
« Reply #57 on: October 26, 2021, 04:41:31 PM »
to be clear (as opposed to being confusing,
1 4 7
2 5 8
3 6 9
try this:
Don't trip about the LED staying on in bypass. Once you've solved this, the other solution just requires snipping a ground wire and re-routing it.
Govmnt_Lacky
« Reply #58 on: October 27, 2021, 07:03:08 AM »
                                          I
Red LED Cathode -----------  I   ___
                                          I
                                          I
Ground wire -----------------  I   ___
                                          I
                                          I
Blue LED Cathode------------ I   ___
                                          I
Wire from +9VDC ------------> 4K7 resistor ------------> Directly to LED anode
zachlovescoffee
« Reply #59 on: October 27, 2021, 05:17:47 PM »
                                          I
                                          I
                                          I
                                          I
                                          I
                                          I
Thank you! I believe I understand how it works now. Unfortunately, the bi-color LED isn't going to work as I don't have a great way to mount it. So, I am going to use two LEDs (blue/red).
Would I then run a dedicated +ve to each LED along with a CLR or do I run one wire from +ve with a CLR and then split it < at the CLR and run a line to each anode of the LED? Then each cathode would go to the switch lugs and the center lug to ground?
