Author Topic: how can i make a boss ds-1 behave more like a fuzz pedal?  (Read 2668 times)
snow123
Re: how can i make a boss ds-1 behave more like a fuzz pedal?
« Reply #60 on: November 24, 2021, 12:19:25 AM »
I can't see why it should misbehave now. Are you sure you disconnected the right pot wires in the DS-1? IIRC, there's a flat cable from the pots to the PCB and the ones to disconnect are I think numbered 7 & 9.
You should still have the DS-1 4.5v reference on all of the DS-1 tone & level pot lugs.
wait so i disconnects tone 2 and level 3 from the pcb, and wire the lpb1 in/out to the pots? just making sure i have this right.
snow123
« Reply #61 on: November 24, 2021, 12:20:33 AM »
'cause ive been wiring the lpb1s in/out to where the pots are wired on the pcb.
anotherjim
« Reply #62 on: November 24, 2021, 04:19:52 AM »
Yes. If you look at the PCB copper trace, you'll see those 2 pot wires are simply connected to each other and don't go anywhere else but it means your LPB-1 is bypassed by the existing connections if you leave the wires connected.
Croeso i Diystompboxes.
There is no aspect of human endeavour that cannot be improved with cheese.
snow123
« Reply #63 on: November 24, 2021, 05:24:21 PM »
wait how do i only disconnect those wires? 'cause its on a ribbon cable, and the ribbon cable is glued there.
anotherjim
« Reply #64 on: November 25, 2021, 04:52:47 AM »
Snip!
snow123
snow123
« Reply #66 on: November 26, 2021, 06:57:07 PM »
« Last Edit: November 26, 2021, 07:21:10 PM by snow123 »
anotherjim
« Reply #67 on: November 27, 2021, 03:44:28 AM »
You have 3 options.
You can cut the wire at some point along the cable. Got a craft knife/scalpel? Slit the web between the conductors and snip out a portion of the wire.
Use a rotary tool/Dremel with a burr and grind away the PCB copper trace between the 2 pot wires.
Chop out the glue around the wire so you can unsolder it.
snow123
« Reply #68 on: November 28, 2021, 11:08:23 PM »
You have 3 options.
ok, i used an exacto knife to cut out the glue, and clipped those wires off, and now everything works perfectly and sounds amazing! thank you
snow123
« Reply #69 on: November 28, 2021, 11:43:50 PM »
You have 3 options.
wait there's 2 things that are happening now, the pedal starts hissing (but starts squealing with an overdrive hitting it) when the level is at 10, and the level control kinda stops increasing the actual volume after 12 o clock, and starts increasing the gain a little bit.
« Last Edit: November 28, 2021, 11:58:05 PM by snow123 »
anotherjim
« Reply #70 on: November 29, 2021, 04:57:09 AM »
This is all inevitable. Putting a gain circuit after a distortion amplifies the noise it makes. The LPB-1 is an inverting circuit and the input booster in the DS-1 circuit also inverts allowing positive feedback conditions within the DS-1 when the gain is high.
You can reduce the gain of the LPB-1 easily by increasing the value of R5 currently 390 ohms according to the Beavis schematic I linked earlier. You could try 1k there. If possible, fit a 10k trimmer pot so you can tweak it.
snow123
« Reply #71 on: November 29, 2021, 12:34:43 PM »
what about the volume pot not really increasing the volume past 12 o clock
anotherjim
« Reply #72 on: November 29, 2021, 01:33:49 PM »
There are circuits after the Level pot. At some point, these are clipping and it can't go louder (I suspect the bypass JFET Q7 doesn't like too much level. Not surprising, the LPB-1 has enough gain to do this. But you have it working in principle so only need to lower the LPB-1 gain to suit. Lowering the gain will also reduce the noise generated by the LPB-1 itself.
snow123
« Reply #73 on: November 29, 2021, 11:39:53 PM »
ok, thank you.
