P Version for 2N5457, j201, mpf102
Started by spoontex, January 22, 2022, 11:52:48 AM
spoontex
Anyone knows the P Channel version for this transistors?
2N5457
J201
MPF102
Thanks.
If you're looking for complementary pairs, no AFAIK. PJFET are actually rare.
pacealot
I have found some 2N5460s that spec out somewhat closely (JFET relative, of course) in terms of VP and IDSS to the 2N5457, but I'm not aware of of "complements" to the other two. If they need to "match," you might be in for a long hunt, as Ranko indicates. The J175 might get you close-oid to the MPF102, if by "close" one means in the manner that Jupiter is "close" to Saturn.  :)  JFETS are really something else. Good luck!
"When a man assumes, he makes an ass out of some part of you and me."
spoontex
Thanks.
I want to experiment with buffers and positive ground effects.
I will have a look.
Quote from: spoontex on January 22, 2022, 12:57:51 PM
No offence but buffers don't mind about transistor channel carries and ground "faces" JFETs Drain & Source indiscriminately.. :icon_wink:
spoontex
Quote from: antonis on January 22, 2022, 02:24:50 PM
No offence, don't worry about that! Can I use a N Jfet with positive ground? I need to learn something about jfet's...
Thanks.
Quote from: spoontex on January 22, 2022, 02:44:58 PM
As far as VGS = 0 V and Drain - Source are interchangeable, proceed without any reservation..
spoontex
Quote from: antonis on January 22, 2022, 03:07:53 PM
Thanks.
Sorry for my laconism but you'll have to study a bit JFETs curves vs BJTs ones.. :icon_wink:
(in the mean of BJTs are strongly dependent both on power supply polarity and p-n or n-p junction boundary where JFETs are only prone to VGS sign/value..)
spoontex
Quote from: antonis on January 22, 2022, 03:27:56 PM
I need to study a lot of things...  :icon_redface: hehe. Thanks!
anotherjim
#10
To convert to positive ground, you have to sort out the connections for correct polarity for the active device (your N JFET) and actual ground which will now be the positive supply rail.
Starting at the top, +9v will now be ground.
Volume pot ground will stay at ground. The 22n cap removes DC to the pot so polarity doesn't need to change. If that cap was are larger electrolytic, its polarity would need reversing.
The 1M gate resistor and the 1k5 source resistor change from ground to -9v to suit the N-channel device.
The 22uF source bypass cap reverses polarity and stays connected to ground. It could stay the same polarity and connect to -9v instead of ground, however, it must really connect to the true circuit ground via a low impedance path to that ground and that is now the positive supply.
The biggest change is due to the gate voltage now being referenced to -9v instead of ground, so we now have DC voltage on the circuit input that needs to be removed. So you must add a series input cap into the 68k "grid stopper", 10nF will do.
Jim, can you see a circuit dia in this thread that I can't? cause I can't.
[edit: sorry I missed the party for 5000, too.]
anotherjim
Ah, the HHTP didn't have no S. Fixed now?
excellent. now we can have a 5007 party.
