PWM Question Tim Esc....?
Started by Arn C., August 25, 2003, 02:17:54 PM
Arn C.
http://www.geocities.com/tpe123/folkurban/fuzz/snippets.html
Just wondering, if I put the EZ LFO in the PWM circuit, do I put the collector to pin 3 of 40106 and still leave the .005 uf cap and 500K pulse width pot hooked up the way it is?
Also,  when I hook this EZ LFO to pins 12 & 13 of the 40106, I will assume that I eliminate the pin 13 to ground?
Arn C.
Tim Escobedo
Yes, if you wish. Just set the PW pot to maximum resistance to get the full effect of the oscillator.
QuoteAlso, when I hook this EZ LFO to pins 12 & 13 of the 40106, I will assume that I eliminate the pin 13 to ground?
Yes. Grounding the unused inputs is necessary. However, in this case, that inverter will be used, so no need to ground the input.
