Author Topic: SOLVED: HM-2 clone, high pitched shriek when Lo is dimed  (Read 2324 times)
matopotato
Re: SOLVED: HM-2 clone, high pitched shriek when Lo is dimed
« Reply #40 on: May 18, 2022, 04:42:19 PM »
Forget all about DC here.. :icon_wink:
Impedance hates DC 'cause it neutralizes reactive components..
(caps turn into open circuit and inductors to short circuit.. - resistors, frankly, don't give a damn..)
Vs is signal amplitude and Vin is a portion of Vs, according to above mentioned formula..
About spectral view: IMHO, 3 measuremets at lower, higher and mid-band frequencies of interest should be adequate..
Thanks. It's the + and - that is confusing. AC don't really have any constant polarity in a specific location over long time. I thought. Of course momentarily there is a polarity unless "0", but not as connections would go.
So I didn't understand how to interpret the figure.
But if I scrach the polarities and think ~ instead, it should be ok. Or I misunderstood completely. (Again ;-) )
"Should have breadboarded it first"
idy
« Reply #41 on: May 18, 2022, 05:16:39 PM »
Yes, for our purposes scratch the polarity and think AC source fro signal.
The example schematic shows the simplest example, with a series R and a shunt R. In real life a signal encounters R, C and L. L is usually left out because its so small. But in a power supply or wah-wah pedal, it becomes important.
Really we mostly deal with R and C. Those two values, Zs and Zl, stand for impedance in series with the signal and impedance loading the signal. That impedance can come from a resistance, capacitance or inductance. Or (in real life) all together. But we measure impedance in ohms, like R, but it changes with frequency.
The way a cap works we can think like this: at some high frequency it has no impedance to the signal. At some low frequency the cap treats it like DC. You can make that reactance into an ohm value. With a simple tone control type filter we are putting a C in one direction and an R in the other. At the frequency where the signal sees equal "resistance" (really impedance) in both directions you have 1/2 the voltage, 6db less signal.
antonis
« Reply #42 on: May 18, 2022, 05:27:08 PM »
 :icon_lol: :icon_lol: :icon_lol:
No, you've got it absolutely right.. :icon_wink:
P.S.
It's a matter of convension for AC voltage sourses to be depicted with positive and negative poles for been distinguished the current send and return paths inside a closed loop (network)
