Hi,
This is a separation from @Wook22's thread
https://www.diystompboxes.com/smfforum/index.php?topic=129191.0 that I felt I was hogging too much for my own problem.
The symptoms are quite similar, and the builds are quite similar.
My original problem was that when I turn up Ratio towards 3 o'clock and Threshold around 9, there is a distorted sound. Not quite like a good distortion pedal but imho worse.
I started a thread for help here
https://forum.pedalpcb.com/threads/thumb-sucker-compressor-scrapy-sound.10516/ back in early February and I got some good hints that I tried out. But the problem remains. The link also have photos and a sound sample of what I mean by distorted sound.
There is also a sense that Attack and Release does very little, but that could be a secondary fault to the first one.
Then it went in to hiatus until I found @Wook22 had a similar issue, so I piggy backed that thread for a while, but now it's time to make a separate thread.
The schematics are here
And if you want the pcb and zoom in the schematics the build pdf is here
https://www.pedalpcb.com/docs/ThumbSucker-PedalPCB.pdfAnd not to worry, although there are pictures in the linked other forum I will produce new ones.
I have recently re-heated all solder joints.
I have traced the connectivity on legs as much as possible trying to avoid direct solders when possible.
I tried to measure the components on the board, which checked out except for:
Threshold B1M
Ratio A1M
R101 and R102
D100 hard to get some sensible reading.
I swapped out C5 and C6 from Electrolytes to Film MKT. Forgot I had and swapped back to Electrolytes despite I had then learned it should not matter. And it didn't. Wish I hadn't swapped back. (And had better memory.)
I installed a trim for R10, and it is set to ~1k
The VREF and VCC plus ground all measure ok.
All reading further down.
What I have done:
Swapping TL072s and LM13700Since there are two in this build I can swap them. No change. Later on I measured pin 7 on IC2 and it was zero, swapped again and now pin7 on the new IC2 got a reading. And so did the other pin7. Probably irrelevant or not pushed hard enough in the socket. Just mentioning.
I also got an opportunity to check another LM13700 from my friends Engineer's Thumb build and no change in my build regardless of LM, and his build sounds just fine.
Swapping the 2N3906I tried with other PNPs and with an old Germanium one the distortion is much less. But not gone. The hfe of this Ge was quite low, so I doubt it is a "fix", but more of reducing symptoms.
Trying two JRC 4562Supposed to be less noisy, I tried with these and it reduced the distortion. In combo with the PNP. Plus using 18V I felt that the problem was almost enough "smoothed out", but turning some knobs the distortion appeared again but with other settings. Not as loud, but still there. So this also feels like a way to lessen the symptoms without finding or fixing the problem.
ProbingIt is clean until I hit IC1. Pin 3 is fine, but pin 2 and 1 (more loud) are distorted, as well as the C2 after. So stopped there.
The Threshold pot Pin 3 is fine, pin1 to VREF is quite silent and pin 2 sort of ok. IC2 pin 3 fine, pin2 slight sparkle, pin 1 bad, but nowdays very bassy. D1 Kathode is fine but slightly sparkly, R3 too and leg 1 on Release pot. But the other legs on Release are bassy distorted. The D1 anode and D2 are bad.
Small caps parallel with D1On recommendation I tried 47pF, 82pF and 120pF, but no real change. Feels more like the category of trimming a circuit than trying to find the root cause for the distortion.
Scope trialsGot a tone generator and a 1-channel scope to probe around, and it was a clear flat top of the signal wave. But not the bottom of it. Might explain why this distortion sounds different than a pedal intended for that purpose.
3mm LEDsFor a while I thought they were causing problems since one of them measured really flimsy values but the other firm.
And they both shone quite bright. Until I swapped the ICs again, then back to "quiet" and the dodgy one stopped being that.
with looper/signal only power no signal
feed VCC Vref feed VCC Vref
9.10 8.91 4.45 9.10 8.90 4.45
IC1 IC1
4.8-5.06 8.91 4.55 8.90
4.46 4.45 4.46 4.45
4.07 4.36 rising 4.08 4.43
0.0 4.35 dropping 0.00 4.43
IC2 IC2
4.50 8.91 4.66 8.89
4.46 3.9-4.7 4.44 3.88
4.27 4.43 4.26 4.43
0.0 4.25 0.0 4.25
IC3 IC3
1.10 0.0 1.35 0.0
0.0 0.0 0.16 1.69
4.46 0.0 4.43 1.45 jumpy 0.25
4.45 0.0 4.44 0.36
4.47 0.0 4.45 0.31
0.0 8.91 0.0 8.89
0.0 0.0 0.0 0.0
0.0 0.0 0.0 0.0
PNP PNP
C 1.16 1.20
B 3.9-4.7 3.85
E 4.45 4.38
Next stepsWill probably put back the C5 C6 as Film Caps MKTs again. Feel it got worse with electrolytes.
During my testing I have never really gotten much change out of Attack and Release. And sometimes the way the compression is released when the tone fades it come on very obvious and not smooth at all. So this together makes me wonder about if this circuit will ever contribute to the pedal chain,
But during the swap-fest yesterday I had some moment of clarity when all remedies were working toward a greater common good. Then it felt just fine and worth all these efforts. I touched a knob and the scraping came back in some places and others not. I fiddled mostly with Threshold and Release when this happened.
I've just about suspected everything, re-heated/soldered all and some twice and maybe more.
I have a hard time accepting the design should be faulty as such considering it is a popular pedal and others did not have my issue.
The problem solver in me wants to find out what the problem is. Would be a boost of morale if nothing else.
And I have had great help in this forum before.
But I am also nearing the point where I would order another kit and start fresh. I have knobs and drilled box, so that is worth a try.
Or just give up as the first one that failed on me. (OK I re-bought re-built an American 60's Fuzz Pro (?) (a Fuzzrite clone), but that was me destroying the board until it was just useless. 2nd build ever. I like to think I have evolved since...)
And either buy a good compressor from a shop or settle with the Zirconia (Diamond Comp clone) opto-comp that is quite nice.
