Author Topic: Coloursound Jumbo Tonebender  (Read 363 times)
Baranouil
« on: June 04, 2022, 03:52:51 PM »
Hi guys,
I recently built a coloursound jumber tonebender following this layout:
I have 2 issues there:
1 I need to almost turn all the way up the volume pot to have decent amount of sound. Any idea from where the problem could come from?
2 Also I have almost no gain. Do you think it could come from the fact i replaced all the 500pf caps by 680pf caps? And replaced all the transistors (BC184C) by 2N5088 transistors?
Here is the schematic:
Re: Coloursound Jumbo Tonebender
« Reply #1 on: June 04, 2022, 03:56:16 PM »
Numbers 1 and 2 are the same complaint. It's not the parts you used.
https://aronnelson.com/diywiki/index.php?title=Debugging
antonis
« Reply #2 on: June 04, 2022, 05:31:33 PM »
It might be the parts you used, if those parts are of wrong value..
e.g. 82k instead of 8k2 and/or 47k instead of 470k..
Or 1k instead of 100R, or 1k5 instead of 15k or.. or..
andy-h-h
« Reply #3 on: June 05, 2022, 02:54:33 AM »
Hello
Point 1.  Could be a number of things causing this.  Photos and voltages if you can?  Otherwise its a guessing game.
Point 2.  No - changing transistors and those caps will not be responsible for low levels.
Good luck
« Reply #4 on: June 05, 2022, 03:31:55 AM »
Check your transistor pinouts.   If c and e are swapped you could get low gain.
If possible post voltage measurements for the transistors.
Send:     . .- .-. - .... / - --- / --. --- .-. -
Baranouil
« Reply #5 on: June 05, 2022, 11:31:40 AM »
Thanks everyone!
Turns out, transistors were not the right way.
Now everything is working!
