Vox Modelling Amp Foot Switch
Started by THRobinson, June 06, 2022, 03:33:32 AM
THRobinson
Hey guys... I have a Vox VT40X modelling amp, and was wondering, has anyone tried making a 3 or 5 button switch (ie VFS-5) for this?
If so... is it straight forward or very difficult? Are there plans available?
I have a Bandit 112 silverstripe, and I have seen 2-button diagrams for that, which looks very simple. I'm assuming the Vox will be more advanced.
Beginner in DIY Electronics
FiveseveN
It's not as trivial as a passive one but not too difficult:
https://www.docdroid.net/zcIVDL7/vfs5-ver40-schematic-pdf
You can skip about half of it if you don't need the bank switching function or its indicator.
Someone implemented it with an Arduino and PWM if you're more familiar with that: https://github.com/xurxofp/VFS5
THRobinson
I wish I knew how to use Arduino, I wanted to make a pickup winder for guitars and posted looking for some feedback on the Arduino forum and, well... I'll probably just manually do it instead. :D
Quote from: THRobinson on June 06, 2022, 05:00:04 PM...well... I'll probably just manually do it instead. :D
ALL the Golden-Age pickups were wound that way.
