Fuzz Face voltages, please explain?
Started by half_smith, July 07, 2022, 01:46:19 AM
half_smith
how does Q1C have a voltage <1v when it is being fed right off the power rail with only a 33k in between?
Thanks for the help!
FiveseveN
You're forgetting what's in between the collector and ground.
If R1 is 33K, R2 is ~2.8K, Vin is your 9V, then what is Vout?
antonis
I think OP is confused due to positive GND circuit.. :icon_wink:
Q1 Collector actually sits 8.3V HIGHER than -9V (what you call "power rail")
That voltage difference divided by 33k calls for a Collector current of about 250μA (conventional current flow fron GND to -9V) and a VEC of 700mV..
Vivek
This article might help to understand transistor bias
https://www.electronics-tutorials.ws/amplifier/transistor-biasing.html
Basically you have -9V at the top rail and 0 on the ground
There is a collector resistor and a voltage drop Vce Collector to emitter in between these rails
There is -8.7V drop across the collector resistor
Hence there is -0.7V across the Collector to Emitter.
Since Emitter is at ground, Collector is at -0.7V
All adds up properly. -8.3V drop and -0.7V drop = -9Volts.
Quote from: half_smith on July 07, 2022, 01:46:19 AM
Because Q1 sucks.
antonis
half_smith
another quick one
in this MAX1044 voltage inverter module, is the 9+ from the DC Jack supposed to connect to the "+" on the board that runs to pins 1,8 of the MAX1044? as is there's nothing going to those pins...
Is that 2n3906 loop a buffer?
antonis
half_smith
thanks Antonis, I cross-referenced some other bipolar charge pumps and MAX1044 datasheets, turns out there's a trace from 2n3906 C to the +9V rail (MAX1044 p1,8)
-it was occluded on the above pic by text
I am pretty unclear what that does, buffer I guess?
I had a 1044 pop on me earlier today and so I'm looking at GGG style for more, um, safety.
antonis
Quote from: half_smith on July 08, 2022, 05:02:57 AM
Can't be sure without a schematic but I suspect (mainly by purple jumper between E & C) it's a current series pass transistor..
half_smith
Anyway, I'm taking your advice and building out the PNP with positive GND (gonna actually use a battery!)
-I've run out of leads from my board's PSU anyway
antonis
Quote from: half_smith on July 08, 2022, 05:48:32 AM
It's not MY advice..
It's YOUR choice..!! :icon_wink:
half_smith
"Don't get me wrong but I'd suggest to start building a Si n-p-n Fuzz Face, then pass to Si p-n-p one, then pass to Ge p-n-p one and THEN pass to Ge p-n-p with bipolar supply.." -Antonis
I agree with your suggestion and choose to follow ;)
half_smith
Hey guys, just back with an update.
Took me a few days to make sense of the "positive GND" stuff. I'm dyslexic as is, so trying to think backwards made me nuts.
Anyway, I got it straightened out. Very fuzzy. I put the "Bias" and "Contour" pots on the board so the pedal only has has the two original knobs but I can easily tweak it.
I had my first chance to use it as an outdoor gig and when it got hit by the sun it went out of bias, I kinda enjoyed that knowing what was happening...
*bonus, my transistor tester came in and I was able to get a great combo of Q1 hfe 80, Q2 140, and it's really nice fuzzy stuff.
thanks for the backup!
antonis
Quote from: half_smith on July 18, 2022, 11:17:14 PM
Next project will be a light/temp bias servo.. :icon_wink:
