AionFX Artemis mkI - Voltage doubler without the footswitch
Started by tmsmtz, July 26, 2022, 08:06:53 AM
tmsmtz
Hi!
My first post, and I am not a very experienced pedal builder. I am building a dual channel SFT(Artemis mkI). I am planning to use it as an always on pedal, and place it on top of my cab as a console type thing. It will only have a power switch, and no footswitches. So, the question I was hoping someone would be kind to answer, is how do I solve the wiring where the footswitches should have been on the voltage doubler boards? Thanks!
welcome to the forum, tmsmtz.
the short answer is where are your build docs? the longer answer is - there will be a wirepad from the in jack and one to the out jack on that board. there will be a wirepad signal to the board.circuit and one from the board/circuit. just link with a wire the jack-in pad to the to-board pad, and link the jack-out pad to the from-board pad. or - follow the tracks from those pads to the footswitch pads, and link-wire across the switch pads instead.
Quote from: duck_arse on July 26, 2022, 10:56:54 AM
....where are your build docs? ...
Google "dual channel SFT(Artemis mkI)" and get:
Artemis Midtown ....Nashville's first Micro Apartments
Artemis Place Makati Hotel offers 23 air-conditioned accommodations with minibars
Artemis Hotel in Bodrum, Turkey
ARTEMIS HOTEL $126 ($̶2̶0̶7̶) - Cefalu
Artemis,Breathtaking view,Schinias, Athens,home/private pool ...
This Artemis II 2-piece microfiber sectional sofa with full sleeper is so easy to
____________________
tmsmtz
Thanks guys! -I will try this. I Really appreciate your help.
