Author Topic: War Scythe/hoof reaper volume  (Read 380 times)
« on: August 06, 2022, 02:28:09 PM »
The tone bender and octave sides work just fine. But the muff side only works if gain and volume is turned all the way up. Is this a transistor issue? I've never encountered this problem before and am unsure how to troubleshoot. I did the cloven mod listed in the build doc.
https://www.pedalpcb.com/docs/WarScythe.pdf
idy
Re: War Scythe/hoof reaper volume
« Reply #1 on: August 06, 2022, 02:40:34 PM »
What transistors did you use for Q4 and Q5? 2n1308? Those "tabs" shown on the PCB are for the emitters. Did you check the pinout of those two transistors?
« Reply #2 on: August 06, 2022, 03:13:02 PM »
Doh! You know what happened? Somewhere along the way I damaged the PCB between q5 base and the resistor after it. Made a jumper and now the fuzz runs free.
« Last Edit: August 06, 2022, 05:30:00 PM by SprinkleSpraycan »
« Reply #3 on: August 06, 2022, 06:17:04 PM »
Works now. But still low volume. Any thoughts?
idy
« Reply #4 on: August 07, 2022, 12:45:43 AM »
Didn't answer my question. Yes, using transistors with wrong pinout will produce your problem.
rogeryu_ph
« Reply #5 on: August 07, 2022, 04:18:06 AM »
The circular drawn with TAB on the PCB call for alloy junction germanium transistor TO-5, any replacement could but the emitter should be near unto the TAB drawing.... that is what idy pointing out. check the transistor datasheet replacement for pin out.
