To quickly jump back to the bias stuff, is there any way you might be able to explain how the Manual pot works? It looks like it is mixing both the +15V and -15V in some way. Seems to make sense that the Manual pot would do nothing with Intensity pot at 10 as it would allow the sine wave at IC12 pin1 to flow through and cut off the voltage from the Manual pot.
R106 and R108 divider the voltage. That's pretty normal thing to do. The idea being is the Manual control only needs to shift the delay a certain amount. The swing of the LFO triangle wave is probably around +/-9V or +/-10V. The manual control after R106/R108 is about +/- 9.6V. So that pretty normal that the range of the Manual Control matches the LFO. The Q21, Q22 circuit just buffers the reduced Manual voltage and produces the Manual voltage at Q22's emitter.
So the Depth pot simply mixes the LFO voltage and the Manual Voltage. At low intensity the voltage at the Intensity wiper varies +/-9.6V (say) depending on where the Manual pot is set. At full intensity it the voltage at the Intensity wiper varies +/-9.6V at the LFO rate. In between settings let you set how much swing the LFO has and the Manual control moves that up or down a bit to set the middle of the delay.
All totally normal stuff.
Basically just wondering what changing the resistance of either the Manual pot, or the 100K resistor right after it would do. With Intensity at 10, the frequency range is perfect (100kHz to 1mHz), but it would be nice to be able and have the Manual pot range match when Intensity is at 0. If I try to get VR3 and VR4 close to the "correct" range, the sweep of the actual full Intensity flange is crazy and sounds insane, the range goes down super low and super high.
So it should already do that.
One thing be careful about is: When you use the Manual control it is very easy to measure the clock. As a result you can see that the manual control isn't reaching the limits in the Service Manual. *However* what if the VCO or the VCO adjustments are the cause and not the Manual control circuit. To me the Manual control circuit looks fine (You could verify the range of voltages at the emitter of Q22 is +/- 9.6V at the Extremes of the manual control.) If the VCO isn't meeting spec with the Manual control then it won't be meeting the spec when the LFO is sweeping. With Intensity on full it should sweep the full clock range as well (or close to it). This is more difficult to measure so you are less likely to pick up a problem, even though the same problem exists with both the Manual control and the LFO waveform. That's also why it's not a good idea to"patch fix" the behaviour based on only what you see with the Manual control. You probably need to dig further. So first verify the voltage range Q22 is +/- 9.6V. Then verify the LFO swings +/- 9.6V at IC12 pin 1 (it will actually swing a little less due to the filter.)
The RC network which can remove the ticks is R1 and C1 on this pic,
https://postlmg.cc/MMB6RsdzIf the value R*C is too big it will slow down the LFO a biit.
Would there be any use in adding a second-order filter for power? Essentially changing it from the left image to the right image?
From what I can see normally +/- 15V rails come from the power supply and hit the two cap C48, C47 which are the filtering for the whole board. The +/-15V rails then go to IC11.
So other than C48 and C47 there's not a lot of supply filtering.
In order to add filtering to IC11 (the LFO) you would need to replicate a circuit like R94, R95, C43, C44 then power IC11 from that "new" filtered power rail.
Like all these mods you have to try stuff to narrow down the problem. Sometimes the things you try don't fix the problem ... because that doesn't turn out to be the problem. There's no easy way to know without trying it.
