I have a feeling I killed the BBD.
If pin 12 and 13 on the 4013 (TP 6 and 7) are good, that means everything before it should be good right (for example, Q18 and Q19)? I'm getting the full correct waveform that changes with Manual, and speed makes it bounce/modulate.
IC12, pin1 gives a sine wave, but the issues seem to show up out of the pin 7 area. 'Sometimes' it gives a correct sine wave, but strangely it will sometimes be quite noisy/glitchy or break up very easily.
Pin15 on the BBD also does this weird glitchy sine wave. The strange thing too is that if I hook up the scope and turn on the synth, the wave will be a bit more clear, but if i take off the probe and put it back on, it is a mess. This happens on pin 2 as well, where it looks like a mix of the modulating LFO and the synth signal, with a ghost sort of waveform trailing behind it but in time. If I unhook the probe, then rehook it, it is a mess.
The only other thing I can think is that CD4013 truly dont work in this circuit, and it needs to be the Motorola one to actually function.
___________
At the same time, I feel like it might not be the BBD though.
I am getting SOMETHING at TP8, which is the output of the BBD, it just isn't pretty. I feel like I should be hearing something and not just only the clean synth signal. I might need to follow the path between the incoming signal, into the BBD, out of the BBD, and towards the effected signal output/feedback signal loop. Maybe I should put together a little audio probe, so I don't have to just use the visual of the scope? I guess anything I am hearing I'd see on a scope though.
I feel like I owe you all a bunch of money or something for all the time you've spent trying to help me! Sorry to keep saying 'thank you' over and over, but thank you!
