Author Topic: Effects Layouts EF120 - No output, Signal dying at Q1 SOLVED  (Read 1311 times)
« on: January 24, 2023, 07:55:28 PM »
This is the EF120 from Effects Layouts, clone of the DA120. I got it all populated and looking good, plugged it in and...nothing. After a visual inspection and reflowing some questionable joints, I tried the audio probe. The problem starts, as far as I can tell, at Q1. Signal going into the gate/center leg is strong, but when I touch the probe to the other two legs I get what sounds like the signal trying to get through but fizzling out instead. Like it's starving the signal somewhere in there.
Thought it might be a power issue but I went over the power section and it seems ok, I have voltage at pins 4/11 of IC 1 as well, and the LED lights up. I'm kinda stumped other than maybe a bad BS170. After Q1 I can hear the same weak, farty audio signal with zero sustain at D1, R3 and R4 and then it's pretty much gone. Any help is appreciated, sometimes I just need a fresh pair of eyes to ID the issue I've been staring at for hours.
Build doc: http://effectslayouts.com/wp-content/uploads/2022/11/EF120-build-doc.pdf
« Last Edit: January 26, 2023, 12:25:58 PM by pangeadestructor »
Re: Effects Layouts EF120 - No output, Signal dying at Q1
« Reply #1 on: January 25, 2023, 08:34:08 AM »
I have voltage
no sir, we need much more than "have voltage". measure all the voltages, post all those measures. all the transistors, all the IC's, all the supplies. please.
Dormammu
« Reply #2 on: January 25, 2023, 08:56:52 AM »
My advice is to apply the input signal (through the cap) bypassing the cascades one by one. So you will find out where the signal is lost.
GibsonGM
« Reply #3 on: January 25, 2023, 08:57:46 AM »
Welcome to the forum, Pangea
An easy to see pic of the actual schematic would be helpful (rather than a PDF...some ppl like myself have issues with them). Then we'll have a common image to refer to so we can send you on your way to do some fixing!   :)  back of the PCB shots are good too, since a good % of problems will be found there.
antonis
« Reply #4 on: January 25, 2023, 09:10:25 AM »
Aye aye, Sir.. :icon_wink:
Govmnt_Lacky
« Reply #5 on: January 25, 2023, 09:57:20 AM »
C2 installed backwards
for an amount of ‘up to and including my life.’
antonis
« Reply #6 on: January 25, 2023, 10:17:53 AM »
Eagle eye.. :icon_wink:
(but that doesn't justify the above described circuit behavior..)
Govmnt_Lacky
« Reply #7 on: January 25, 2023, 10:46:47 AM »
Possibly but, fixing found mistakes may prove to change the discrepancy. Start with the easy stuff and proceed  8)
« Reply #8 on: January 25, 2023, 11:03:45 AM »
Thanks for all the replies so far, got some voltages to share.
IC1
1 8.62   5 -7.48
2 4.49   6 7.65
3 0      7 3.96
4 -3.42   8 8.62
IC2
4 8.62   11 -7.48
Q1  S 4.29 G 6.29 D 4.32
Q2  S 4.31 G 6.28 D 4.32
Q3  S 4.30 G 6.20 D 4.29
Q4  S 4.30 G 6.18 D 4.29
« Reply #9 on: January 25, 2023, 11:05:42 AM »
See this is what I'm talking about when I mention a fresh set of eyes. I looked at that at least 10 times and thought "yup, looks good to me." Good looking out, thanks. I'll swap that out shortly and see what happens.
« Reply #10 on: January 25, 2023, 04:10:03 PM »
Corrected the C2 polarity, no change but it needed to be done anyway.
antonis
« Reply #11 on: January 25, 2023, 04:30:16 PM »
You must have a supply issue around IC2..
Check R30/R31 values/ratio or better check VR,,
(it should measure about 60% of VC..)
Q1 to Q3 are bottomed due to high Source voltage caused by high Gate voltage..
(they should be biased at S: 1/3VC and D: 2/3VC..)
As for Q4, you should be able to bias it (via 100k trimpot) at S: 1/4VC and D: 3/4VC..
« Last Edit: January 25, 2023, 04:44:02 PM by antonis »
Dormammu
« Reply #12 on: January 25, 2023, 05:07:50 PM »
Nope, C2 is installed correctly.
UPD: Oh, shi...  It on the board.  My bad. ¯\_(ツ)_/¯
But it should be taken into account that even the "wrong" polarity in such a connection will work.
« Last Edit: January 26, 2023, 02:32:07 PM by Dormammu »
« Reply #13 on: January 25, 2023, 06:23:34 PM »
Looks like I may have used a wrong value at R30, based on the color code it looks like a 27k when it should be 62k. Gonna pop that out and replace it. R31 is the correct 100k.
« Reply #14 on: January 26, 2023, 01:28:51 AM »
As shown by the voltage on Q1 Gate.
Anything called "Vref" should be reported. We don't ask for that enough.
« Reply #15 on: January 26, 2023, 12:24:07 PM »
I replaced R30, and I have output. Only tested it through my little practice box, but it sounds like I'm in business with this one.
Thank you so much for your help on this, I would have approached the issue all wrong without the assistance.
Govmnt_Lacky
« Reply #16 on: January 26, 2023, 01:38:24 PM »
Good to hear.
Just remember, no matter how simple or complex the circuit... ALWAYS take a few minutes after populating the board to verify resistor values, cap values, cap orientation, IC orientation, etc.
antonis
« Reply #17 on: January 26, 2023, 04:53:18 PM »
¯\_(ツ)_/¯
Do I have your permission for copying that thumbnail..??
Dormammu
« Reply #19 on: January 27, 2023, 02:29:00 AM »
¯\_(ツ)_/¯
No doubt.
