A close photo of your build (both PCB sides) should help a lot..
Thank you, but I don't think pics will be needed. I fixed my mistake : The remaining R3 pcb-soldered leg is grounded, so I needed to add a jumper on the empty R3 pad to restaure the signal path... quite simple, let's say that I was probably tired last night.
Thanks for the suggestion, I can't really notice anything obvious differing from before, and I guess that's a good thing.
Edit: oh ! it sounds like the popping is much less audible, it's kind of silent now... Aahyyaa ! Gloire ! Glory to Antonis !
Blocking DC is effective on popping noises in some cases, I guess ?
I noticed the volume pot is located before IC1 TL72 on schematics. I'm used to see Volume pots at the end of circuits. I wonder what's the function of IC1 ? Is it a cabsim circuit ?
