Author Topic: Troubleshooting a Marshall Supervibe SV1  (Read 1828 times)
antonis
Re: Troubleshooting a Marshall Supervibe SV1
« Reply #20 on: January 28, 2023, 04:48:01 PM »
Too many TL0xx damaged.. :icon_wink:
potul
« Reply #21 on: January 28, 2023, 05:05:57 PM »
In fact, I had to change 3 because silly me, I made an stupid mistake and cut the legs of the wrong IC. So I had to replace IC5 as well, that was working fine. :-[
anotherjim
« Reply #22 on: January 29, 2023, 04:27:32 AM »
I would check around that D5 protection diode. The 1N400x may be ok, but it's not unknown for the PCB track to have fused out instead. A parallel protection scheme cannot be proved to be present and effective unless you test for the reverse path via the diode.
Croeso i Diystompboxes.
Cnicht siarad "nee"
potul
« Reply #23 on: January 30, 2023, 02:23:15 AM »
thanks for the advice. As soon as I open the pedal again I will check it.
