How to plot JFET?
Started by spoontex, February 04, 2023, 03:46:30 PM
spoontex
Clint Eastwood
If you look up the datasheets, you can choose yourself. Look for Vgsoff similar to BF245a. Both 2SK30 and J113 should work I think. FSFX made you a kind offer, I would bite if I were you  ;)
spoontex
At last I found good BF245A!
Here are the results. I need to match two of them. What would be good candidates? This 10 devices are enough? I have more of them...
FSFX
Quote from: spoontex on March 01, 2023, 04:54:20 AM
It looks like devices 4, 5 and 6 are the closest matches.
BTW, not sure how you tested but you seemed to be restricting the current to less than 1mA so this has affected the accuracy of your data for higher current. As the Idss for a 2N245A is going to be between 2mA and 6.5 mA then you are artificially restricting the current so the data at the top of your graph is invalid.
spoontex
Quote from: FSFX on March 01, 2023, 07:43:46 AM
with this circuit:
https://www.axtsystems.com/joomla31/index.php/projects/11-cat-1176ln-audio-compressor/4-art-1176-fet-matching
