FV1 Touch Eurorack
Started by dathey, February 16, 2023, 01:47:10 PM
dathey
My take on the FV1 Touch / Qubit by leetut:
https://www.diystompboxes.com/smfforum/index.php?topic=122800.msg1159250#msg1159250
https://www.reddit.com/r/diypedals/comments/djqmqn/my_latest_fv1_build/?utm_source=share&utm_medium=web2x&context=3
https://youtu.be/RZMjG5Z1gMA
Mods:
1.) Removed meter function
2.) Added adjustable clock and external feedback controls
3.) Added CV for each of the three main control pots (pots 0-2 per datasheet)
4.) Designed for eurorack
Still a work in progress...
Very nice! I love this sort of stuff!  8)
mark2
Looks great! Are you doing PWM for the pot inputs?
dathey
Thanks, but just expanded on the original scheme, of using single and dual pots, that generated analog 0-3.3vdc signals to the stm32.  Ran out of analog inputs on the bluepill...
Ice-9
That's great, I did a similar thing expanding leetut's Qubit to allow for 8 EEPROM chips to give 64 programs. The audio path is a custom preamp which differs to the Qubit. I also removed the ATINY bypass part and added the code to the Bluepill micro dev board instead. I did this because I just really liked the idea and look of the touch screen that letut used with the Qubit.
www.stanleyfx.co.uk
dathey
Trying for 256 effects...wish me luck !
Wouldn't a better approach for 256 effects be to store all the programs in the uP, connect that to the FV-1 and get it to "fake" the EEPROM? It's only a I2C connection or something, isn't it? And I'm sure there's details of what the FV-1 expects flying around, because I remember seeing it once. Adding yet more EEPROMs seems crazy, especially since each one is a 4K chip, and the FV-1 uses only 128 x 8 = 1K of it. So 3/4ths of each chip is wasted!
dathey
Agreed, however, since this is my first foray into programming micro processors, I went with what I knew.
My next approach will be to attempt the Cerebra FV1:
https://youtu.be/m-SGJObDsqk
https://www.dropbox.com/sh/xu3h1muv0b47tbe/AABFHA7vDbswVZ5tQYDD2KEsa?dl=0
Quote from: dathey on February 18, 2023, 08:10:12 AM
Fair enough. Good policy!!
Yeah, that's the thing! All it needs is the control pots off the other one and it's perfect!
