Fuzz Face super loud even at minimum volume
Started by slowpogo, February 27, 2023, 04:19:58 PM
slowpogo
I built an original circuit Fuzz Face using the following guide:
https://tonefiend.com/wp-content/uploads/Fuzz%20Face%20Build_v02.pdf
Everything works and sounds great...except the volume knob (500kA) doesn't seem to minimize volume.
The volume pot seems functional, I measure 500k across the output when at 0%. But the volume only goes from REALLY LOUD to ATOMIC LOUD.  I need to put something after it set way below unity gain, just to use the Fuzz Face without destroying ears/amp.
Any immediate thoughts on this situation?
Dormammu
Plug in another pot 10-200K.
Photos are helpful, if posted.
antonis
If loudness is the issue, make Volume pot 100k ..
(or place a resistor of 100k say between R3/R4 junction and C2..)
GGBB
The volume pot in that circuit should let you turn down to zero. If that isn't working, then you have either a bad pot or a build error. Did you deviate from the schematic and build guide in any way?
slowpogo
Thanks everyone, turns out it was a bad pot. Not sure what happened to it but I simply replaced with another A500k pot, and the volume works great now.
HOWEVER...now I'm getting a "pop" when turning on/off.
I've got some 2.2M resistors, should I add a pull down resistor? where would be best?
Quote from: slowpogo on February 27, 2023, 06:28:41 PM
From C1+ to GND.
pinkjimiphoton
Quote from: slowpogo on February 27, 2023, 04:19:58 PM
10 bucks says no connection between pin one of the volume pot and ground.
Slava Ukraini!
~Jack Darr
^^ In which case, the link between rows L and M is missing?  Got a photo of your build?
antonis
I'd have to argue with both Jimmy and Marc.. :icon_wink:
In case of not grounded pot, 500k (Volume set at min) should be more than enough to cause a significant volume drop by forming a voltage divider with amp input impedance..
pinkjimiphoton
nope.
try it. seen this happen a few times with builds by that douche i used to work for. a variable resistance will have some effect, but without the ground connection? do just what he says. too loud and ungodly loud. ;)
Slava Ukraini!
~Jack Darr
antonis
