Ceramic capacitors. Re-thinking them.
Started by brett, May 21, 2023, 04:43:12 AM
CheapPedalCollector
Quote from: Dormammu on May 21, 2023, 09:45:36 PM
How do you determine the level of humidity in the caps?
They start to be really noisy and make spitting sounds and a lot of white noise. I mostly run across it in old amps, but the occasional pedal. My Distortion + had one like that.
Dormammu
Quote from: CheapPedalCollector on May 22, 2023, 02:58:47 PM
Have you tried drying them with a heat gun?
Weird that the heat from the components in the old amp didn't keep moisture away.
antonis
Heat (by itself) doesn't dissipate moisture..
(dry air circulation does..)
Dormammu
#23
Quote from: antonis on May 23, 2023, 05:40:47 AM
dissipate moisture
I noticed this while cooking jerky with a fan.
Also during the recap of old amplifiers with dried electrolytes.   ;)
