Ordered wrong pots
Started by scotheath, October 28, 2024, 03:36:33 PM
scotheath
Like title says I somehow ordered wrong pots
These "50K OHM Linear Dual Taper Potentiometer Round Shaft PCB 9mm" from tayda.
Don't need the dual part, can I still use these and obviously just use the first set / lower pins ?
I've never delt with dual pots before.
stallik
Yes you can. The pot contains 2 separate wafers which don't interfere with each other electronically.
scotheath
Quote from: stallik on October 28, 2024, 04:21:08 PMYes you can. The pot contains 2 separate wafers which don't interfere with each other electronically.
Right on Thanks
