Updated: Collection of FV-1 Reverb Algorithms Available
Started by taudio, May 12, 2025, 07:23:14 PM
taudio
We've made some updates to the collection of FV-1 reverbs that were previously posted.
As before, this is a combination of algos done in SpinCAD Designer and modified versions of some of the best FV-1 reverbs we found in the FV-1 Programs Archive.
The updates are as follows:
  • The spring reverb incorporates updates from Mick Taylor (aka Ice9) that add an Abbey road studio's R2127 filter to the input to the reverb (passes 600Hz-10kHz); changes to the reverb tone and level controls to be more in line with the Fender 6G15 schematic, putting the tone control at the end of the reverb
  • Fixed a constant in Plate Reverb so it will assemble with SpinAsm
  • Updated all patches except Shimmer to use a Mix control (in place of a Reverb level) that allows adjusting between 100% dry to 100% wet
Here's a recap of what is included:
  • Room Reverb - made with SpinCAD Designer
  • Hall Reverb - made with SpinCAD Designer
  • Plate Reverb - a modified version of the Dattorro reverb coded by mdroberts1243
  • Spring Reverb - a modified version of the spring reverb coded by Don Stavely
  • Shimmer Reverb - a modified version of "Version 6" from DrAlx (which is based on Ice9's shimmer reverb)
  • MN3011 Reverb - made in SpinCAD Designer; based on a classic MN3011 reverb design
  • Room Reverb-3-4-5 - made in SpinCAD Designer (by Digital Larry)
  • Three Tap Delay Reverb - made in SpinCAD Designer
More details are included in the PDF file that comes with the SpinCAD Designer and SpinASM files.
You can download this "best of" collection here. We'll also put in a request to get this included in the FV-1 Programs Archive.
Enjoy!
hery95
Hello,
We've made some exciting updates to our curated collection of FV-1 reverb programs! This set combines custom-designed algorithms created in SpinCAD Designer with modified versions of some of the best community-contributed reverbs from the FV-1 Programs Archive   Official Website
Best Regards
heri
Quote from: hery95 on Yesterday at 12:44:24 AMour curated collection of FV-1 reverb programs
That's a "Cat Meow Sounds Translator" (actually links to apps). Cute, but not a reverb. Honest mistake, or are you in the wrong place??
Yes, cute, but a more-or-less verbatim regurgitation of some of the OPs original post.  Heri's gotta go...
