Volume Pedal (is this a stupid question?)
Started by nils, October 26, 2003, 02:09:16 PM
nils
Hi!
I think I might want to add a volume pedal to my setup; now I do know that the crucial part of building one is the enclosure; but as I have a dead CryBaby lying around, I thought "piece of cake". But then it got me thinking... what's inside a volume pedal besides the obligatory volume pot? It can't be THAT easy, can it?
In other words: are there any schems around for good sounding vol pedals? Or do I just install a pot into the enclosure and that's it?
"If you wind up with a boring, miserable life because you listened to your mom, your dad, your teacher, your priest, or some guy on TV telling you how to do your shit, then YOU DESERVE IT."
- Frank Zappa
J Gagan
I think the Ernie Ball peds are a 500k or 1 meg pot.
You could just wire it like a vol control,
Or you could use the switch hole [ dpdt for true bypass ) of the crybaby to switch between a boosted function or straight vol pedal.
Or switch between buffer and boost would be pretty cool too. This would give the least amount of loss vs a stock vol ped for your cable runs, other peds etc.
J Gagan
Also, try and get a very durable pot.
I find these old military spec pots at the surplus place, I think they are AB from the UK
the have a logo A-B, with a 'G' below, inside an octagon
and they say 'TYPE J'
Big sealed pot.
nils
so passive vol pedals are really that easy made? just the pot and nothing else?
I suppose the vol pedal should then go somewhere after a buffered pedal, right?
- Frank Zappa
ExpAnonColin
Quote from: nilsso passive vol pedals are really that easy made? just the pot and nothing else?
Passive are very easy, yes, but there is quite a bit of tone loss.
The EB's have op amps and what have you in them to make the tone loss not so bad.
-Colin
Arno van der Heijden
My EB has a treble bleed cap across the pot. No opamps though...
bwanasonic
Quote from: Arno van der HeijdenMy EB has a treble bleed cap across the pot. No opamps though...
The standard EB 6166 doesn't have anything other than a switchable resistor to change the pot taper. It does have some tone suck, so some sort of buffer is a good idea.
Kerry M
nils
thanks guys. Fixed me up a quick volume pedal using the old pot of my Wah. Value / range doesn't matter much because it's mainly for muting and a casual swell effect. Have it after my OD pedals (old H&K Tubeman is the last of them) and before my tuner (Boss TU-2), so it should be OK sound wise.
Thanks again.
- Frank Zappa
