Hacking the Alesis Ineko, part 2
Started by drew, November 11, 2003, 03:46:54 PM
drew
Just finished this... here's a list of mods...
Replace U1, U2 with NE5532.
Replace C2, C3, C4, C5 with 0.1uF poly caps.
Replace C7, C11 with 0.1uF poly caps.
That's it. I just hooked it up to a beep box (a tb-303 clone, borrowed from my friend hektor) and ran thru some of the presets. It sounds great. I will post an mp3 sample so you can hear it. My pal makes evil industrial-techno so don't consider this a reflection of my own musical taste :) There is some brief hissy noise around 2:02 but that's the "fuzz" effect with the noise turned all the way up... and I hope you don't sit and listen to this for more than two minutes anyway!
The sample: http://www.toothpastefordinner.com/ineko-sample.mp3
The original picture of the inside: http://www.toothpastefordinner.com/ineko-inside.jpg
The picture of the finished mod: http://www.toothpastefordinner.com/ineko-post-mod.jpg
drew
Peter Snowberg
Awesome! 8)
See my notes in your other thread that I edited into my double post. I was done editing a few minutes after you posted this thread.
Great job! How much did it improve things?
-Peter
Eschew paradigm obfuscation
drew
It GREATLY improved things. Before, it was hard to hear what was going on over the noise... now, you can actually hear that the effects are pretty decent. I have an electronics page I'm cobbling together slowly and I will put some stuff up there when I get it up. Probably in a couple of weeks. At any rate, it was basically unusable before as it added a thick layer of hiss to anything that I put thru it.
(The old thread is here: http://diystompboxes.com/sboxforum/viewtopic.php?t=12109 but I'll answer questions in this thread.)
There aren't any parts on the bottom of the board. It IS double-sided though I think this is probably just to keep them from having to install jumpers, etc.
The cap on the outputs isn't a filtering cap, it's a DC-blocking cap (to keep any DC from hitting the opamps and driving them into saturation on the input side, I assume, and to keep DC from exiting the box.)
You are right about the filter/buffer though... I realized about halfway thru that since it's a stereo box (L/R in, L/R out) that only half of those i/o opamps is working on each side!
drew
