Author Topic: NPN Booster turned into distortion not distorting :(  (Read 6201 times)
smoguzbenjamin
« on: November 22, 2003, 01:12:45 PM »
Hey guys!
I took the booster, and added two diodes (1N4148) back to back to ground -> see schematic:
http://scorpius.spaceports.com/~ubermaus/guitar/npnds.html
But it ain't distorting, boosting, or whatever...  :cry: I went over every solder joint, every part that could go wrong, it's fine. I replaced the transistor with one that I know that works, no difference. I suspect a bad part... Where and what do I measure, guys?
Oh btw I have an el-cheapo multimeter that doesn't have a continuity meter....  :?
aron
« Reply #1 on: November 22, 2003, 06:55:18 PM »
Max the boost and turn down the 10K output volume pot.
It should distort then.
smoguzbenjamin
« Reply #2 on: November 23, 2003, 05:53:49 AM »
Hmmm, I've just realized that turning the boost pot doesn't do diddly squat... I'm gonna have to resolder everything :( Oh well, here's to another day of debugging. At least I learn something when I debug stuff :)
aron
« Reply #3 on: November 23, 2003, 02:56:11 PM »
No, don't redo the whole thing, just the pot to ground and capacitor.
smoguzbenjamin
« Reply #4 on: November 24, 2003, 08:32:55 AM »
I tried the volume pot all the way down to ground, this just shuts the pedal up. Also when I turn the boost, it doesn't make anything happen. Not even with the volume pot disconnected. I'm starved for ideas on what's wrong  :cry:
aron
« Reply #5 on: November 24, 2003, 11:13:45 AM »
Somehow you have the boost pot miswired.
Can you take a picture and send it to me?
smoguzbenjamin
« Reply #6 on: November 24, 2003, 12:40:30 PM »
Hmmmm. I donno when my sister-in-law will be home, she's the only one with a digital camera... Or maybe I'll bring the NPNbooster to a friend or something... I'll see, and try and get you the pic as fast as I can. As for me, I'm going to rewire the boost pot  :)
aron
« Reply #7 on: November 24, 2003, 03:36:22 PM »
OK.
If I saw what you had, I could probably figure it out.
Aron
smoguzbenjamin
« Reply #8 on: November 25, 2003, 09:31:52 AM »
I'm gonna get a pic as soon as I can, don't know when that'll be though  :cry:
aron
« Reply #9 on: November 25, 2003, 11:29:04 AM »
Do you have a scanner?
Put the circuit right on it and scan.
