Lets once and for all get a list of "What you need to s
Started by ExpAnonColin, December 23, 2003, 12:45:26 PM
ExpAnonColin
I know there are a few on Geofex, etc, but I'd say it'd be good to have one in the FAQ's and stuff.  Here's my list, please revise and add, because I'm sure I'll forget things.
PASSIVE
-Resistors of 1, 22, and 47 values (100ohm, 22k, 470k,etc)
-Nonelectro caps - Mostly 1-values, higher values (100pf and up)
-Electrolytic caps - 1, 22, and 47 values
-Potentiometers: 1k, 5k, 10k, 100k
ICs
-Op amps: 741, 071, 082, 4558
(The below are not necessary but recommended)
-Op amps: 3080
-Audio amps: 386
-Timers: 555
Diodes
-1n4001, 1n34, silicon
Transistors
-NPN: 2n2222, 2n3904, 2n5088
-PNP: ?
-Darlington: ?
SWITCHES
-Toggle: A few SPDT
-Stomp: Lots of DPDT and 3PDT, a few SPDT
JACKS
-Mono, 2 conductor 1/4"
-Stereo, 3 conductor 1/4" (about 1/3 as many as mono)
ENCLOSURES
-Hammond 1590BB or equivalent
-Hammond 1590B or equivalent (1/2 as many as BB)
(buy others based on need)
KNOBS
-1/4" shaft with screw
TOOLS, WIRE, ETC
-Soldering iron, low wattage (15-25)
-60/40 low diameter solder
-Set of small screwdrivers
-22-24 AWG wire (pre-tinned preferable)
-Needlenose pliers and wider size pliers
-Wire cutters and strippers
PLACES TO LOOK:
http://ebay.com
http://smallbearelec.com
http://mouser.com
http://experimentalistsanonymous.com/ebaylots ;)
http://www.web-tronics.com/
http://www.digikey.com
http://futurlec.com
That about sums it up for me... what did I miss?
-Colin
