Neovibe problems
Started by Chris S, August 27, 2003, 10:45:34 AM
Chris S
Hello all after builidng a few simple effects (fuzz face, tychobrahe, Brian May treble boost) I am trying build a neovibe. I ordered the board to make sure I didn't stuff that part up. At the moment I have a light but no pulsing. (it was once there but it seems to have gone). The transistors in this section seem to be all working okay and I replaced the one driving the lamp just in case (but since the lamp works I'm guessin that was a bit pointless) any help greatly appreciated.
AllyP
Try searching the archive (Not available from here, you have to go to the main site :))  I believe there was someone else with the same problem not so long ago....I dont know if it got sorted tho...
Chris S
Yer I think that was my question in the old forum, and the advice was to try this one...
Chris S
Okay I know I'm responding to myself but hopefully my journey may help those in the future.
My problem is that at the moment my neovibe sounds like a bad tremelo.
I replaced Q11, Q12 and Q13 with 2n5088s and it "vibed" for about 5 seconds and stopped. Then I replaced them with 2n3904s and it isn't any better. the voltage readings in the lamp section are too high.
Could I be shorting out the transistors??? I am using 24v at 500ma into the unit. Could this be way too much? and if so can I change this without buying a new power pack?
Any help appreciated :lol:
Chris
Chris, see the email I sent you.
The Neovibe has been built by quite a number of people with good results. You may be having problems with a high voltage supply or some of the other things I asked you to check.
