Author Topic: Biased Improperly Questions?  (Read 3755 times)
skeeter
« on: January 17, 2004, 12:11:25 PM »
Now that I got my Electra distortion working...I have to hit the strings pretty hard to get the effect to kick in.
I was reading the DIY FAQ and found the answer...sort of
Here's my question:
When you say the base is "too close" to the emitter, etc.
do you mean distance in voltage or the actual/physical distance, if the base lead was 1/2" away from the emitter lead...does that make sense?
Also, what meter should I use? Standard voltage meter? I'm going to Radio Shack today any "must have" things I should get?
Sorry for all of the questions :oops: , just want to learn it all, Thanks!!!
smoguzbenjamin
« Reply #1 on: January 17, 2004, 01:26:23 PM »
Get a digital multi meter and make sure it can measure at least voltage, resistance and current. Hfe and capacitance is handy ;) But it gets expensive quick.
When you say the base of a transistor is too close to the emitter you're talking about voltage, for instance in a PNP tranny the base should always be about .6 volts above the emitter. You can put the physical leads anywhere you like! As long as they don't connect it's O.K.
aron
« Reply #2 on: January 19, 2004, 01:46:39 AM »
Choose a digital multimeter with hFE transistor measurement and auto pinout identification of transistors if possible.
In any case, even a cheaper digital multimeter will work fine.
One feature I really like is auto-ranging.
This means you set it to DC  or ohms and you don't have to choose a range or anything. You simply measure and the meter will "auto" range for you.
Very handy!
