Electric Mistress Power
Started by saxtim, January 24, 2004, 12:13:48 AM
saxtim
http://www.generalguitargadgets.com/v2/diagrams/dmistsc.gif
Instead of using the transformer can I just use an 18V plug pack and attach it directly to a 15V regulator?
tim
Peter Snowberg
Absolutely. :D
You're going to want to have at least 3 volts above that 15 for the regulator to remain stable. If you don't have that much spare voltage and your regulator is not stable, try using an LDO or Low Drop-Out regulator instead of the 7815. There are many of them these days and they only need a volt or less more than the output voltage to remain stable.
Good luck,
-Peter
Eschew paradigm obfuscation
jsleep
Tim,
If you're using a DC power pack, bypass the rectifier.  Just leave out the diodes and connect directly to the ground and power rail to the regulator.  Maybe I should post a little diagram of that kind of power connection.
JD
For great Stompbox projects visit http://www.generalguitargadgets.com
Bill_F
Quote from: jsleepTim,
JD
That would be helpful. I've got this one on my list of future builds.
Thanks JD.
Bill
saxtim
JD - I think there is an error on the Electric Mistress schematic.  IC5 - There are 9 connections to it (and only 8 pins!).  On the bottom side, you've got pins 4 and 1 connected together and then connecting to D5, then a 3rd (unlabeled) wire connected to ground.  From looking at another schematic on the web I think that pins 1 and 4 should be connected together, and then to ground, not to D5.  Is that right?
tim
jsleep
good catch Tim,  I'll put that on my list of fixes to do.
JD
