Foxx Tone Machine prob.
Started by Xlrator, February 12, 2004, 04:52:56 PM
Xlrator
Been farting around with this one for a day. I get hiss (like it's wanting to do something) but no sound when effect is switched. I probed and I get signal up to the third transistor (5089s). I can hear the signal get fuzz as it goes thru the curcuit, and the octave works when I switch it. Q4 has real faint fuzz on it's base and it's voltages look strange when I measured them.
9.04 supply
Q1 C 4.06 B 1.63 E 1.02
Q2 C 5.47 B 4.06 E 3.44
Q3 C 6.65 B 0.81 E 0.23
Q4 C 9.03 B 0.08 E 0.00
I removed nearly every component and measured individually. I etched JD's layout. All are O.K. I read thru the archives and found JD had fixed problems with the schem. There was one about a .003uF cap to .03uF. The schem has a newer date than that in the archive. ?? The diodes I'm using are 1N34A (RatShacks I think). Are those germaniums?
I'm putting it down so I can get some work done. Anyone have any clues or help on this?
Ben
Listen to cKy!
JohnM
JD's site has a voltage chart.  Check it out.  It looks like your Q4 is especially off.  -John
Xlrator
Yeah, I did check his chart. But I can't figure out why it's way off. All my components seem to check out OK.
Listen to cKy!
Travis
Check for bridges (solder or trace).  The collector of Q4 seems to be directly connected to +9.  I'd check around R23 and C13.
For reference:
http://www.generalguitargadgets.com/v2/diagrams/ftmpl.gif
Xlrator
Yeah, I got a good etch and have no solder bridges. Checked it 10x with a lens. Once my iron heats up, I'm going to replace R23 again. Last time I checked it, it was 10K.
*edit*
Still dead  :x
Listen to cKy!
JonC
Appears to me that Q4 isn't conducting at all -- I'd check the biasing of the base -- the base of Q4 s/b at about 0.81 V, so I'd check that the 470K from +9V to the base is ok.
