new site & pedal
Started by Joe Davisson, February 21, 2004, 09:45:14 PM
WGTP
I'm using 2 GE's in a Black Fire Stage right now, with the standard resistor values.  I'd recomment getting the highest hFe that Small Bear has for sale.
Stomping Out Sparks & Flames
Joe Davisson
You can rebias a Vulcan or Blackfire stage to accomodate any transistor type. PNP Vulcans won't work right because of the diodes. (Untried: A PNP transistor configured as a diode may work in the Vulcan.) Hot humbucker users should alter the parallel resistor/cap values after the gain control, raising the resistance and lowering the capacitance proportionally.
I haven't tried opamps with diode-inputs, but will eventually. With these circuits, the tonal difference between BJT/JFET/MOSFET is not great, besides the amount of available gain.
To my knowledge, the amplifier stages (Vulcan, Blackfire 1/2) are "new". There is a circuit similar to the BF stage whose purpose is to raise frequency response, but that's the only one I'm aware of at this time.
-Joe
swt
Well thanx guys!. Thanks Joe for sharing and for amazing designs!. I've built a blackfire with bc109c, and doug's highway, using the blackfire stage, with bc549c, but still can hear a little hard edge of silicon in there, that's why i was asking that. I'll give this a try with some ac187, ac127, and 2sd352 i have lying around. Thanks again!!.
