Author Topic: New at runoffgroove.com: Thunderchief  (Read 24817 times)
will
« Reply #20 on: March 23, 2004, 04:35:45 AM »
Hi Gary and Brian,
Your Thunderchief looks real good!
I would love to hear the sound clip but I can’t find it on your sound page. http://www.runoffgroove.com/salvo.html#thunderchief
A general question:
Have you tried doing a similar circuit using mosfets instead of the JFETs and limiting the gain to approx 100 like the 12AX7, by adding some resistance to the .68uF source cap? I wonder how close they might sound.
I wonder if part of the secret to the sound is the maxed presence control.
Regards,
Will
Gary
« Reply #21 on: March 23, 2004, 07:40:00 AM »
Will,
The maxed presence control does make a difference.
javacody
  • Total likes: 0
  • Blah Blah Woof Woof --Jimi Hendrix
    • javacody
« Reply #22 on: March 23, 2004, 07:43:30 AM »
Gary, any plans to introduce a perf layout for this baby?
Doug H
  • Guest
« Reply #23 on: March 23, 2004, 09:01:19 AM »
Quote from: Gary
Thanks, all.
Doug, do you remember me asking about the SLO after you released the Meteor?
Yes. I remember that. This CS JFET approach can be applied to a lot of different circuits.
Quote from: Gary
BTW, everyone reading this that has not tried Doug's Meteor, do it now!  You've never heard a distortion pedal sound so good.
Thanks. :D  I have been using the meteor in my weekly gig and am very happy with it. It has exceeded my initial expectations by far, when in a live situation at stage volume. Makes my SS amp sound like a boutique... :D
Doug
B Tremblay
« Reply #24 on: March 23, 2004, 09:06:43 AM »
Quote from: javacody
I plan to draw one today, actually!
B Tremblay
runoffgroove.com
Arno van der Heijden
« Reply #25 on: March 23, 2004, 09:14:33 AM »
Try using different JFETs. J201s provide more gain than the actual amp had. It sounds great, but may be too hot for some. Try lower powered JFETs for a milder, more classic sound.
Any suggestions for this?
What parameter should I be looking at in a datasheet? How much gain does a 12ax7 have?
javacody
  • Total likes: 0
    • javacody
« Reply #26 on: March 23, 2004, 10:13:24 AM »
Awesome Brian! I don't know what I'd do without Runoff Groove. You guys keep me busy!
I would really like to know, once I have the thunderchief done, how to do something similar for the famous 60's Marshalls.
B Tremblay
« Reply #27 on: March 23, 2004, 01:12:47 PM »
A (currently untested) perfboard layout has been added to the Thunderchief page: http://runoffgroove.com/thunderchief.html
B Tremblay
runoffgroove.com
BILLYL
« Reply #28 on: March 23, 2004, 01:33:43 PM »
As others have said - Runoff Grove keeps me busy.
Listen to the clip last night and the 14yo said - "Now that's the sound I'm looking for!"
I drew up a  EXPRESS PC layout.  Would like to have someone verify - please email if interested.
Thanks again-
BILL
javacody
  • Total likes: 0
    • javacody
« Reply #29 on: March 23, 2004, 01:52:56 PM »
What would 680nF be in uF?
B Tremblay
« Reply #30 on: March 23, 2004, 02:00:09 PM »
That would be .68uF
0.1uF = 100nF
0.01uF = 10nF
0.001uF = 1nF = 1000pF
We've decided to adopt the Euro notation style for new content at the 'Groove.  It reduces the confusion (though not in this case!) and gets rid of the pesky zeros when labeling the layouts.
B Tremblay
runoffgroove.com
Jered
« Reply #31 on: March 23, 2004, 02:08:39 PM »
Javacody,  that would be .68uF Arno, try 2N3819, 2N5457, 2SK30, or for more gain 2SK117, 2SK118, and 2SK184. MPF 102 fets will work but your not going to get the gain this pedal wants to sound really good.
  Good luck,  Jered
Gary
« Reply #32 on: March 23, 2004, 02:20:07 PM »
Arno,  check this out from the DIY FAQ:
"What FETs can I substitute in the Mini-Booster and Shaka etc...? I can't find the J201....
From Jack Orman:
This is a recurring question eventhough the information was in the Mini-Booster article at AMZ From the article: "The NTE458 usually has more gain than the J201, and the 2N3686 can provide gain of 500. The 2N5457, MPF102, and 2N3819 will produce less gain. Other substitute transistors include 2N5484, 2SK43, 2SK68, 2SK117, 2SK118, 2SK121, 2SK163 and BF245."
Java,
This circuit is based on the '70 Super Lead schematic on www.schematicheaven.com  The older amps are not very different.  It should be easy to change things around and have a JTM45.
javacody
  • Total likes: 0
    • javacody
« Reply #33 on: March 23, 2004, 02:31:48 PM »
Thanks guys,
I figured I just divide nF by 1000 to get uF, here is a parts list I threw together:
Resistors:
68K
2 - 1M
2K7
470K
2 - 1K
2 - 4K7
470
220K
2 - 15K
100K
Capacitors:
2 - 0.68uF  (680n)
3 - 0.0022uF (2.2n)
3 - 0.022uF (22n)
470p
2 - 0.1uF (100n)
100uF
Pots:
4 100k (trim)
1M Audio
100K Audio
JFET's:
4 J201's
Jacks:
1 Stereo
1 Mono
Switches:
1 DPDT or 3PDT
Does that look right to everyone?
B Tremblay
« Reply #34 on: March 23, 2004, 02:45:07 PM »
Looks like you got them all!
B Tremblay
runoffgroove.com
puretube
« Reply #35 on: March 23, 2004, 03:10:49 PM »
javacody
  • Total likes: 0
    • javacody
« Reply #36 on: March 23, 2004, 09:57:17 PM »
Would a 500K gain pot, effectively lower gain on this effect?
yes
« Reply #37 on: March 24, 2004, 12:36:26 AM »
...try a 1 meg resistor, connected to lug 1 & lug3 of the 1M Pot
  Adjust as necessary
bwanasonic
« Reply #38 on: March 24, 2004, 01:28:10 AM »
Come to think of it- how come Marshall never did this themselves? Seems they went mostly the diode clipping route with their stompboxes, didn't they?
Kerry M
Alex
« Reply #39 on: March 24, 2004, 01:33:59 AM »
Quote from: bwanasonic
Kerry M
...and with their amps too ;)
