Phase 100
Started by u1061810, April 11, 2004, 07:37:55 AM
u1061810
Hi, Does anyone know where to find a schematic for the Phase 100? Thanks for any help.
vdm
GGG.... im not sure if the site is down currently..... but it works on my computer.... its probably in the cache though....
you can try it if you'd like
www.generalguitargadgets.com
trent
RetroTones
Interestingly enough, I just finished getting my old script Phase 100 back to life after it being out cold for years. It works and sounds beautifully again. Watch that 4-way switch wire-up shown in the schematic. It doesn't work right the way it is depicted. Switch positions were bass-ackwards. Now I used the replacement switch (ECB194) from Dunlop which is NOT the same one that was used in the original script MXR's. http://www.jimdunlop.com/support/faqs/elec_parts.html  If you use their switch, set the tabbed washer to hole 4 for 4 positions. With pads numbered right to left, from component side, wire pad 9 to terminal A, pad 7 to terminal 2 > jumpered to 1, pad 4 to terminal 8 > jumpered to 10, and pad 2 to terminal C. I pulled my original script PCB to service later and installed a calibrated original MXR one purchased from Gear Trader who may have more. http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&category=41420&item=3711016262  Very economical considering parts costs, availabilty, and labor.  End result: That lush, clear, psychedelic phasing that only the P100 ever delivered - and with all the intensity settings at their correct positions. Good luck & regards!
