>if you would please take a look, the wiring is totally off, way off compared to the explaination that you drew,
I can't. Everytime I check geocities tells me the quota is over limit and I can't view anything.
>but the 100K wires pot used for electra distortion, will be missing from the DPDT switch and has to be done something right?
I have no idea. I bet the 100K pot is a volume pot so one outer lug is the output of the effect, the other outer lug is ground and the middle goes to the switch.
>and i thought i would take a look at the first link of yours and your NPN boost 5k pot has some 0.47k stuck on it on the middle ring(?) of the pot...
Yes, that's because this booster circuit has a .47uF (not K) capacitor across the lugs. This is different from your circuit.
>oh and also shield sleeve tip ring? what are those?
This is in the DIY FAQ which I hope you have read:
http://www.diystompboxes.com/cnews/FAQ.html
>and some line stating "the connection can be made through metal chassis"
what does it mean by that?
I don't know. A connection through the metal box used for the pedal?
>the ground connection, is there a good reading about this??...and what does he/she mean when saying Large circles for screw and nut and 2 mall for jacks' ground?
Sounds like there are large circles in the picture for screws and 2 small circuits where the jack's ground connects.
Aron
[/img]
