foxx tone machine... treble cut?
Started by marrstians, August 29, 2003, 09:46:25 PM
marrstians
i built a foxx tone machine and it sounds rather well... the only problem is that when the octave is engaged it produces too much treble.... is there a way to cut the treble just from the octave circuit? thanks....
daniel
Ansil
120-470pf cap to ground, if this isnt' enough try adding a higher value,
To the highs roloff cap at the output to create an adjustable amount of roloff...
 Take a look at 'simple mods' fro the 'transition page' [old forum page that you use to get here]
Ammscray
Quote from: marrstiansi built a foxx tone machine and it sounds rather well... the only problem is that when the octave is engaged it produces too much treble.... is there a way to cut the treble just from the octave circuit? thanks....
daniel
Adjust the treble cap in the tone control circuit...make it slightly bigger...check everything else too, because on my tone machine even with the tone control cranked, it's not too much and it sounds great!
"Scram kid, ya botha me!"
