Would this work?
Started by Alpha579, June 21, 2004, 05:06:33 AM
Alpha579
To simulate the sag of a valve rectifier, when it cannot keep up with the demands of current by the amp...
 For the battery supply, Use a Jfet as a constant current source ie drain connected to Battery, gate connected to source via resistor, then get supply from source...
BUT heres the twist, you use a fet as a variable resistor instead of the fixed resistor, then you use an envelope detector on the input to control the resistance of the fet, thus changing the current dragged from the supply...
Probably completely wrong, but it was worth a shot... :)
Alex Fiddes
smoguzbenjamin
If you do it right you could get something cool out of that... however since the supply voltage is much much lower you're not going to have as much effect. A 1k resistor on a 300v B+ is going to make much more difference than a 1k on 9v ;) So take that into account.
Alpha579
Just so you know, this is what its meant to look like:
Alex Fiddes
puretube
Jason Stout
If you copy and paste the url you can see Alpha579's schematic.
http://www.geocities.com/alphaeffects/Sagidea.jpg
Jason Stout
Alpha579
Sorry, yeah, copy url into new ie page...
Alex Fiddes
