YA Simple OD/Boost....
Started by ExpAnonColin, August 02, 2004, 05:06:48 PM
ExpAnonColin
Someone from the HC boards commissioned me to build then a light overdrive, this is what I came up with.  Since I'm at work, and love being off task, I thought I'd draw a schematic up quick...  It actually doesn't sound bad at all, especially for the amount of thought I put into it.  It *does* have some very very light mis-bias crackle at the decay... but it really does overdrive quite nicely, it's sort of a treble boost with some nice light clipping capabilities.
Thought I'd post it for the OD addicts/newbies looking for a simple project.  The perf layout is realyl straightforward, so I didn't think I'd post what I ended up doing (it only took me maybe an hour, and I got it right the first try...)
Any schem mistakes/bad design recommendations are appreciated of course...  The 100? value  I can't remember from work, so play around with it either way.
Cheers!
-Colin
Signal path> Base tied to ground, that's a small amount of resistance.
 I think I'd start somewhere like 470k or twixxed 100k -  1meg
travissk
QuoteIt *does* have some very very light mis-bias crackle at the decay...
Crackle OK!  :P
ExpAnonColin
Quote from: petemooreSignal path> Base tied to ground, that's a small amount of resistance.
Run that through me again?  What exactly are you referring to?  The initial 690 ohms to ground on the first base?
-Colin
puretube
being aware of the risk of being misunderstood ( :wink: ) :
the 10µF el. cap after 1st transistor should be replaced by a link
(=dead short, omit, direct connection...);
it doesn`t do anything
but reducing the effective value of the following 0.2µF cap
by about 2%.....
ExpAnonColin
Quote from: puretubebeing aware of the risk of being misunderstood ( :wink: ) :
by about 2%.....
Thanks... wouldn't have seen that myself.
-Colin
puretube
at the risk....
837k is very close to 820k in series with 18k...
ExpAnonColin
Quote from: puretubeat the risk....
I only buy/use 10, 47, and 22 values.
-Colin
I'm sorry to have interjected like that, [fishing for feedback on resistor values from base to ground?...could be], ...I should have used the trusty '?'.
puretube
me too would insert a "k" for the "?"
0.1µF/690R is s.th like a low-impedance ~2khz hi-pass,
which in turn doesn`t require a big 10µF afterwards,
supposed there`s s.th. left to amplify at all, when gain pot
is maxed, loading the pickup with the series 0.1/690...
ExpAnonColin
I was using that resistance to ground to decrease the amplitude of the oncoming signal, basically as a fixed pot at a very low setting...  not realizing of course that I was creating a HP filter, which explains the hotter sound of the box.
-Colin
