Parts question for Mouser
Started by wef200, September 13, 2004, 03:06:40 PM
wef200
Can anyone give some advice on a few part numbers for mouser.
I am building a fuzz pedal and I need to order some 'High End roll-off" caps for the rocket fuzz schematic.  It calls for a .1uf, I believe the High end roll off... means that it has a very high Q rating, is this correct? Im not quite sure which capacitors will work best from mouser?
Thanks for the help
aron
Any .1uF cap will work. You can use any film type 16V or higher.
