MXR Dist + and DOD 250 question...
Started by Steben, September 14, 2004, 09:39:47 AM
Steben
Hi guys,
Just wondering if the sound would be much influenced by IC clipping. If one should put a pair of let's say... LED's in the feedback loop of the opamp (and thus blocking the chip to "hard clip"), would the sound be much different?
Certainly, in principle, dual clipping stages will have a sonic impact.  Whether than impact is audible in any given context is another matter.
The LEDs will have a much higher clipping threshold than the diode pair that follows the op-amp.  What that means is that the signal will be severely clipped by the GE diodes long before the LEDs are pushed hard enough to have any impact.  You *could* replace the GE diodes with Si diodes to reduce the discrepancy in clipping threshold between the LEDs and diodes, or simply stick the diodes after a second gain stage that would let you adjust how much gain is applied to the signal for each set of diodes.
In the case of the Dist+ as well, the use of a 741 op-amp restricts the amount of usable headroom.  Many builders, myself included, who thought they would be clever and score themselves a clean booster for the price of a switch position (to lift the diodes out of circuit) soon found out that the Dist+ is rarely clean, even without diodes.  The 250 may be a different beast.
Steben
Yes, thanks for the reply and sharing knowledge ;-)
I was thinking maybe the IC already distorts in the stock pedal, but the GE's clip the signal more off (but softy, so the timbre of the IC clipping remains...). So I guessed without the IC clipping or with soft clipping on the IC, the sound would be less mushy...
